Edimax Wireless HD Day/Night Pan/Tilt Cloud Camera with Temperature Sensor
Quicklinx: BYR4WS00 Mfr#: IC-7113W
  • microSDHC Card
  • microSD Card
£90.65 ex VAT
£108.78 inc VAT
The Edimax IC-7113W 720p HD Pan and Tilt Wi-Fi network camera is a versatile monitoring device ideal for monitoring your home, shop or factory during the daytime and at night. With Edimax Plug-n-View technology, no complicated setup is required and you can easily connect the camera to the cloud and monitor remotely from a smartphone, tablet or laptop.
The IC-7113W features a motion & sound detection system, two-way audio, built-in microphone & speaker, built-in selectable lullabies, temperature & humidity sensor and a microSD/SDHC card slot. Motion and sound-triggered recording ensure that you capture any unusual activity and the wireless user interface allows for easy installation and monitoring.
Smart HD Wi-Fi Pan/Tilt Network Camera with Temperature & Humidity Sensor, Day & Night
  • Plug-n-View for 24/7 Remote Monitoring with free EdiView II app on iPhone, iPad or Android or EdiView software for computers
  • Night Vision with infrared LEDs and auto light sensor
  • Motorized Pan & Tilt for wider viewing angle
  • Multi-Area Motion & Sound Detection triggers recording and sends to email or ftp
  • Push Notifications with Video Alerts when motion or sound is detected
  • Two-Way Audio with built-in microphone and speaker for easy on-site communication and alerts
  • Acoustic Echo Cancellation (AEC) ensures crisp and clear sound quality during two-way audio communications
  • Built-in Lullaby can be played through the network camera to sooth your child to sleep
  • Temperature & Humidity Detection with Push Notification Alerts when above or below preset levels
  • Wireless & Ethernet Connection for flexible placement, and compatible with IEEE 802.11b/g/n products
  • Easy Setup & WPS Support
  • Plug-n-View for easy 24/7 remote monitoring
    Edimax Plug-n-View technology makes it easy for you to keep an eye on your yard, garage, shop, factory or other assets wherever you go. With Plug-n-View technology you can connect your network camera to the cloud in a few simple steps and access it remotely with a smartphone, tablet, or computer no matter where you are.
  • Motorized pan & tilt
    With the ability to pan ±355 degrees and tilt ±120 degrees, the IC-7113W gives you a wider viewing angle than the average network camera.
  • Motion detection triggered recording
    The powerful built-in multi-area motion detection system ensures that you have evidence of any unusual activity. You can pre-define multiple areas in the monitored range for motion detection; and when motion is detected in the specified areas, the network camera will produce video footage of the event immediately - storing the data on a microSD/SDHC card or sending it automatically to email or FTP.
  • Sound detection triggered recording
    The IC-7113W also features sound detection capabilities with a built-in microphone. When sound is detected, the network camera will take video footage of the event immediately in the same manner as with motion detection, and store the files locally on a microSD/SDHC card or send to email and FTP.
  • Push notifications with video alerts
    Push notifications are triggered by sound or motion detection, and when a detection system is triggered the IC-7113W additionally sends video alerts to email or microSD card. If the camera ever goes offline, push notifications are also sent when the camera comes back online to keep users informed about any unusual activity.
  • Two-way audio
    The network camera incorporates a speaker and microphone for two-way audio support, so you can remotely communicate at the camera's location such as comforting a baby with mom's voice or activating a deterrent alarm - a vital, cost-saving and potentially even life-saving additional security tool.
Edimax IC-7113W - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
11.2 cm x 12.8 cm x 11.6 cm
251 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS
Minimum Illumination
1 lux
Focal Length Control
Fixed focal
Lens Iris
F/2.0
Panning Range (degree)
-355 to +355
Tilting Range (degree)
-120 to +120
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 12 V
E-mail alerts, Motion Detection Technology, light sensor, infrared cut filter, Wi-Fi Protected Setup (WPS), temperature sensor, Plug-n-View, notification picture to FTP, humidity sensor, reset button, Audio Detection
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
11.2 cm
12.8 cm
11.6 cm
251 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
1 lux
Infrared LEDs
8
Infrared Distance
4.6 m
Video Capture
1280 x 720 @ 30 fps , 640 x 360 @ 30 fps , 320 x 176 @ 30 fps
RAM
128 MB
Flash Memory
8 MB
Image Sensor
CMOS
Lens Construction
Fixed focal
Lens Iris
F/2.0
Panning
Range (degree)
-355 to +355
Tilting
Range (degree)
-120 to +120
Network Interface
Network Protocols
DHCP, DNS, FTP, HTTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, IPv4, RTCP, PPPoE, SNTP
Supported Memory Cards
microSD Card, microSDHC Card
Mounting kit
1 x network cable - external
FCC, RoHS
Power Requirements
DC 12 V
Power adapter - external
Software Included
Drivers & Utilities
Relative Humidity (operating)
Brand: Edimax
