Enjoying high-speed wireless network access is as simple as plugging the Edimax EW-7612UAn V2 into your computer's USB port. This high-gain wireless USB adapter is a quick and easy way to add high-speed wireless connectivity to your desktop, laptop, or notebook computer. You can enjoy data rates of up to 300 Mbps when the Edimax EW-7612UAn V2 is connected to wireless 802.11n standard devices.
The Edimax EW-7612UAn V2 allows for increased wireless coverage and higher data transmission rates. The latest wireless technology is built into this device to broaden its wireless coverage by 5 times and to reduce dead spots within the wireless range. The EW-7612UAn V2 complies with wireless IEEE 802.11 b/g/n standards and can reach data transmission rates of up to 300 Mbps when connected to wireless 802.11n devices. It also extends its wireless signal distance, and provides more reliable wireless connections than standard IEEE 802.11 b/g wireless networks.
The EW-7612UAn V2 has a built-in 3 dBi high-gain antenna, which enables it to achieve better signal quality compared to common USB adapters. The included hardwire USB cable also allows users to easily adjust the USB adapter's angle and placement for better wireless performance. The EW-7612UAn V2 has adopted a clever protocol for smarter management of power usage. This wireless USB adapter smartly adjusts its power output according to transmission distance and CPU offload. It drastically reduces power consumption when the connection is idle. Designed with green WLAN technology, the EW-7612UAn V2's power consumption can be reduced an average of 20% to 50%.
Wireless 802.11n standard
The Edimax EW-7612UAn V2 allows for increased wireless coverage and higher data transmission rates. The latest wireless technology is built into this device to broaden its wireless coverage by 5 times and to reduce dead spots within the wireless range. The EW-7612UAn V2 complies with wireless IEEE 802.11 b/g/n standards and can reach data transmission rates of up to 300 Mbps when connected to wireless 802.11n devices. It also extends its wireless signal distance, and provides more reliable wireless connections than standard IEEE 802.11 b/g wireless networks. -
3 dBi antenna and a hardwire USB cable for improved wireless performance
The EW-7612UAn V2 has a built-in 3 dBi high-gain antenna, which enables it to achieve better signal quality compared to common USB adapters. The included hardwire USB cable also allows users to easily adjust the USB adapter's angle and placement for better wireless performance. -
Green WLAN for improved energy efficiency
The EW-7612UAn V2 has adopted a clever protocol for smarter management of power usage. This wireless USB adapter smartly adjusts its power output according to transmission distance and CPU offload. It drastically reduces power consumption when the connection is idle. Designed with green WLAN technology, the EW-7612UAn V2's power consumption can be reduced an average of 20% to 50%. -
Hardware WPS (Wi-Fi Protected Setup) button
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. If the wireless device with which you wish to connect supports WPS, the Edimax EW-7612UAn V2 will automatically set up the wireless connection with a robust WPA data encryption.
- Edimax EW-7612UAN V2 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.5 cm x 1.5 cm x 15.5 cm
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, USB 2.0, IEEE 802.11n
- System Requirements
- Microsoft Windows Vista / XP / 7
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Link/activity
- Access Point operational mode, WMM support, QoS, WPS
Aerial
- Gain Level
- 3 dBi
- 1 x aerial
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- FCC
- Software Included
- EZmax Setup Wizard
- OS Required
- 1.5 cm
- 1.5 cm
- 15.5 cm
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
