Edimax USB 3.0 Network adapter
Quicklinx: 991VWS00 Mfr#: EU-4306
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: PC, Mac
Type: Network adapter
£14.08 ex VAT
£16.89 inc VAT
With speeds up to 5 Gbps, USB 3.0 is fast becoming the standard in data-transfer technology for PCs and laptops. However, some computers only feature 10/100 Ethernet ports while Macbook Airs and often Ultrabooks don't feature Ethernet ports at all. Existing USB 2.0 Gigabit Ethernet adapters are limited by the USB 2.0 maximum data rate of 480 Mbps while the USB 3.0 adapter can reach speeds of 5 Gbps.
  • USB 3.0
    The EU-4306 supports USB 3.0, the newest specification of the USB standard which specifies a maximum data transmission speed of 5 Gbps. Up to ten times faster than the existing USB 2.0 standard which is restricted to a maximum speed of 480 Mbps, USB 3.0 enables the full capacity of 10/100/1000 Mbps Gigabit Ethernet to be reached through an existing USB port with no need to install a Gigabit Ethernet card.
  • Ideal for Ultrabooks
    For Ultrabooks or a Macbook Air with no Ethernet port, use the USB 3.0 Gigabit Ethernet adapter for simple plug-and-play Gigabit Ethernet network connection capability. Take the compact, portable EU-4306 wherever you take your laptop and ensure you stay connected to fast, reliable Gigabit Ethernet whenever you need. Provide Gigabit Ethernet connectivity for desktops, laptops, game consoles or home network appliances.
  • Supports jumbo frames
    Support for jumbo frames can offer dramatic improvements in network performance and raise effective bandwidth. Jumbo frame are Ethernet frames (data packets) of up to 4000 bytes per frame, in comparison with standard, significantly smaller 1500 byte Ethernet frames. Using larger frames means that fewer frames are sent across the network which improves CPU cycles and bandwidth. For some applications, especially those typical of Gigabit Ethernet use such as large file transfers, the result is greatly increased network performance.
  • Power saving
    The EU-4306 incorporates a power saving feature to reduce power consumption by up to 35% when there is no Ethernet activity, reducing costs and contributing to a better environment.
Edimax EU-4306 - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
2.8 cm x 1.36 cm x 7.32 cm
23.5 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
Apple MacOS X 10.6, Linux Kernel 2.6.x, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Power, link/activity
Flow control, WOL, USB powered, Jumbo Frames support
1 x 1000Base-T - RJ-45
1 x SuperSpeed USB 3.0 - 9 pin USB Type A
FCC
2.8 cm
1.36 cm
7.32 cm
23.5 g
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Compatibility: Mac
Brand: Edimax
