Edimax USB 2.0 to 10/100Mbps Ethernet Ad
Quicklinx: 991RWS00 Mfr#: EU-4208
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
£8.34 ex VAT
£10.00 inc VAT
The Edimax EU-4208 USB 2.0 Fast Ethernet adapter is specifically designed to give Fast Ethernet connectivity to your ultrabook, or any computer without an Ethernet port. Simply plug this Fast Ethernet adapter into a USB 2.0 port on your ultrabook, and you can instantly gain access to a stable 10/100 Mbps Ethernet connection. The EU-4208 is also a quick and convenient way to add Ethernet connectivity to a desktop computer without the hassle of opening up the computer case. It is backward compatible with the USB 1.1 standard.
  • Made for the ultrabook
  • USB 2.0 for full 10/100 Mbps Ethernet performance
    Compared to USB 1.1 adapters, which only offer 12 Mbps transmission speed via USB, the EU-4208 is designed with the USB 2.0 standard and able to transfer data at 480 Mbps, ensuring full 10/100 Mbps Ethernet performance without any compromise.
  • Compact design and power over USB
    The Edimax EU-4208 comes in a compact design, making it easy to use in a crowded workspace. With power over USB support, this Ethernet adapter can work without an additional power adapter.
  • Low power consumption
    The Edimax EU-4208 is designed to use power efficiently and prevent unnecessary waste of power. It can dynamically lower its power supply for low power consumption in idle mode and low traffic conditions.
Edimax EU-4208 - network adapter - USB 2.0 - 10/100 Ethernet
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
2.2 cm x 6.6 cm x 1.5 cm
25 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
RAM
20 KB
IEEE 802.3, IEEE 802.3u, USB 1.1, USB 2.0
Apple MacOS X 10.x, Microsoft Windows 2000/XP/Vista/7
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Status Indicators
Link/activity
Auto-negotiation, USB powered
Processor / Memory
RAM
20 KB
1 x 100Base-TX - RJ-45
1 x USB 2.0 - 4 pin USB Type A
FCC
600 mW
2.2 cm
6.6 cm
1.5 cm
25 g
70 °C
Protocol: Ethernet
Compatibility: Mac
Compatibility: PC
Brand: Edimax
