Edimax Fast Ethernet 16 Ports Desktop Switch
Quicklinx: BYQZWS00 Mfr#: ES-3316P
Type: Fast Ethernet
Ports: 16
Hurry, only 1 left in stock!
£28.08 ex VAT
£33.69 inc VAT
16 Port Fast Ethernet Switch
The ES-3316P is an energy saving network switch with sixteen integrated 10/100Mbps Fast Ethernet ports. The power saving function saves resources and is light on the pocket, meaning the ES-3316P is an ideal solution for homes and small businesses.
200Mbps Full Duplex Transmission
The ES-3316P complies with IEEE 802.3/IEEE 802.3u 10/100Mbps Ethernet standard and also supports IEEE 802.3x full duplex transmission. The full duplex feature can double the network throughput on every port and is used for high speed server or switch-to-switch connections. The ES-3316P boasts a maximum throughput of 200Mbps for every port.
Supports Wire Speed and Flow Control
The ES-3316P’s built-in non-blocking and store-and-forward architecture equips your network with full-wire speed connections. It accommodates flow control for full duplex mode and back pressure for half-duplex mode; ensuring reliable data transfer and preventing data loss. Use the ES-3316P to create high-speed networks and benefit from exceptional performance and reliability.
Supports Auto-MDI/MDI-X and Auto Sensing
The ES-3316P supports PnP (plug and play) installation and auto-MDI/MDI-X, meaning you can connect to computers or Ethernet devices without configuration hassles. For your convenience you can use either straight-through or cross-over Ethernet cables and connect both 10 and 100Mbps devices to the ES-3316P. The switch intelligently detects the correct cable and speed for your device.
IEEE Energy Efficient Ethernet (EEE)
The ES-3316P offers environmental efficiency together with Fast Ethernet speeds which are critical for next-generation network applications. To comply with the IEEE802.3az standard, the ES-3316P provides power saving functions to reduce costs and energy consumption.
  • 200 Mbps full duplex transmission
    The ES-3316P complies with IEEE 802.3/IEEE 802.3u 10/100 Mbps Ethernet standard and also supports IEEE 802.3x full duplex transmission. The full duplex feature can double the network throughput on every port and is used for high speed server or switch-to-switch connections. The ES-3316P boasts a maximum throughput of 200 Mbps for every port.
  • Supports wire speed and flow control
    The ES-3316P's built-in non-blocking and store-and-forward architecture equips your network with full-wire speed connections. It accommodates flow control for full duplex mode and back pressure for half-duplex mode; ensuring reliable data transfer and preventing data loss. Use the ES-3316P to create high-speed networks and benefit from exceptional performance and reliability.
  • Supports Auto-MDI/MDI-X and auto sensing
    The ES-3316P supports PnP (Plug and Play) installation and auto-MDI/MDI-X, meaning you can connect to computers or Ethernet devices without configuration hassles. For your convenience you can use either straight-through or cross-over Ethernet cables and connect both 10 and 100 Mbps devices to the ES-3316P. The switch intelligently detects the correct cable and speed for your device.
  • IEEE Energy Efficient Ethernet (EEE)
Edimax ES-3316P - switch - 16 ports
Switch - 16 ports
Subtype
Fast Ethernet
Ports
16 x 10/100
MAC Address Table Size
8K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
16 cm x 10.7 cm x 4 cm
215 g
Switch - 16 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
16 x 10/100
8K entries
Status Indicators
Power, link/activity
16 x 100Base-TX RJ-45
External power adapter
1.72 Watt
FCC, RoHS
16 cm
10.7 cm
4 cm
215 g
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 16
Brand: Edimax
Price Range Ex VAT: 0 - 50
