Edimax AC600 Dual-Band Mini USB Adapter
Quicklinx: 991WWS00 Mfr#: EW-7811UTC
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11a, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • IEEE 802.11n
£27.50 ex VAT
£33.00 inc VAT
The 802.11ac wireless standard is set to revolutionize Wi-Fi. Super-speed 802.11ac dual-band routers are already available but wireless devices are still stuck with 802.11n technology. Upgrade your wireless device to dual-band 802.11ac with the fastest possible USB 2.0 connectivity for blistering Wi-Fi speeds on the interference free 5 Ghz frequency band.
  • Wi-Fi standard
    The Edimax EW-7811UTC is the next generation of Wi-Fi adapter, compatible with the draft 802.11ac standard and delivering speeds of up to 433 Mbps at 5 GHz - almost three times as fast as 802.11n. Upgrade PCs and notebooks to super high speed 802.11ac Wi-Fi and enjoy streaming video and data.
  • Dual-band connectivity
    Enjoy better performance and greater flexibility for your Wi-Fi devices, using dual-band connectivity. The EW-7811UTC provides connectivity for the 2.4 GHz band at speeds of 150 Mbps or 5 Ghz band at speeds of 433 Mbps. You can surf the Internet and check your email on the 2.4 GHz band, or select the 5 GHz band for online gaming and video streaming.
  • ownload and stream anywhere
    Use the EW-7811UTC to download and stream media from YouTube, Netflix or other services without waiting for buffering, or stream media across your network from a NAS (network-attached storage) at lightning speeds. Streaming HD movies or downloading is faster and more reliable than ever with 802.11ac Wi-Fi.
  • Compact & convenient
    Designed for efficiency and performance, the mini-sized adapter is lightweight, sleek and portable. Incorporating 11ac technology into users' lifestyles and unlocking a world of potential Wi-Fi applications, the low-profile mini-adapter sits almost unnoticed in any USB drive and travels with your laptop wherever your lifestyle takes it.
  • Wi-Fi Protected Setup (WPS) button
    The EW-7811UTC has a one-click Wi-Fi Protected Setup (WPS) button to help you set up and activate a secure wireless network in a snap.
Edimax EW-7811UTC - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.6 cm x 0.7 cm x 4 cm
3 g
802.11a, 802.11b/g/n, Wi-Fi 5
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac (draft)
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
WPS
Aerial
Antenna
Internal
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC, RoHS
Software Included
Drivers & Utilities
1.6 cm
0.7 cm
4 cm
3 g
0 - 95% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11a
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac (draft)
Compatibility: Mac
Compatibility: PC
Brand: Edimax
