Edimax 300Mbps Wireless miniUSB adapter
Quicklinx: 991SWS00 Mfr#: EW-7722UTN V2
Wired / Wireless: Wireless
Protocol: IEEE 802.11g, IEEE 802.11b, IEEE 802.11n
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • IEEE 802.11n
£12.34 ex VAT
£14.80 inc VAT
The EW-7722UTn V2 is a high-speed wireless USB adapter that boasts maximum range and speed. This wireless USB adapter can achieve data transfer rates of up to 300 Mbps when connected to wireless 802.11n devices, which is 5 times faster than a 802.11g connection. Enjoying high-speed wireless network access is as simple as plugging the Edimax EW-7722UTn V2 into your computer's USB port. This is for sure the trendiest way to upgrade your wireless network connectivity.
  • Wireless 802.11n standard (data rates up to 300 Mbps)
    The Edimax EW-7722UTn V2 gives you increased wireless coverage and higher data transmission rates. The latest wireless technology is built into this device to broaden its wireless coverage by 5 times and to reduce dead spots within the wireless range. The EW-7722UTn V2 complies with wireless IEEE 802.11 b/g/n standards and can reach data transmission rates of up to 300 Mbps when connected to wireless 802.11n devices. It also extends its wireless signal distance, and provides more reliable wireless connections than standard IEEE 802.11 b/g wireless networks.
  • Green WLAN for improved energy efficiency
    The EW-7722UTn V2 has adapted a clever protocol for smarter management of power usage. This wireless USB adapter smartly adjusts its power output according to transmission distance and CPU offload. It drastically reduces power consumption when the connection is in idle. Designed with green WLAN technology, the EW-7722UTn V2's power consumption can be reduced an average of 20% to 50%.
  • Features a hardware WPS (Wi-Fi Protected Setup) button
    Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. If the wireless device to which you wish to connect supports WPS, the Edimax EW-7722UTn V2 will automatically set up the wireless connection with a robust WPA data encryption and authentication. The Edimax EW-7722UTn V2 wireless USB adapter supports both hardware (push-button) WPS and software WPS configuration.
  • Hardwire USB cable for improved wireless performance
    EW-7722UTn V2 comes with a free hardwire USB cable for improved wireless performance. When using the EW-7722UTn V2 with the hardwire USB cable, it provides better wireless performance at no extra cost.
Edimax EW-7722UTn V2 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
3.58 cm x 1.78 cm x 0.91 cm
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link/activity
WMM support, WPS
Aerial
Antenna
Internal
Antenna Qty
2
1 x USB extension cable (external)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
Software Included
EZmax Setup Wizard
3.58 cm
1.78 cm
0.91 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: Edimax
