Edimax 2-Port PS2 KVM with audio - Connects to PC with USB port
Customer rating: 4.0* (Write a review)
Quicklinx: 4MWQWS00 Mfr#: EK-UA2C
EK-UA2C is a 2-port USB KVM switch to control two computers using a single VGA monitor, PS/2 keyboard, and PS/2 mouse. With built-in 1.2M KVM cables, you can connect to computers and devices easily. The compact size can save your desktop space. It supports hotkeys, push button and auto scan. Its completed keyboard and mouse emulation for simultaneous PCs boot-up process. The Hot Plug feature let you connect/disconnect PCs without powering down PCs. EK-UA2C supports most of operating system (DOS, Win3.X, Win95/98/98SE/ME/XP/7/2000/NT, Netware, Unix and Linux...). It also supports Microsoft IntelliMouse and Logitech NetMouse. No power supply and softward needed, just plug and play. it supports audio feature so you can share one set of speakers for 2 PCs.
Edimax EK-UA2C - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
7.3 cm x 7.2 cm x 3 cm
420 g
Microsoft DOS, Microsoft Windows 3.x, Microsoft Windows 95, Microsoft Windows 98, UNIX, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows Millennium Edition, Microsoft Windows XP
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
Max Video Bandwidth
250 MHz
Status Indicators
Status
2 x audio mini-jack , 2 x VGA HD-15 , 2 x USB Type A , 1 x keyboard (PS/2) , 1 x VGA HD-15 , 1 x audio mini-jack , 1 x mouse (PS/2)
2 x keyboard / mouse / video / audio cable - 1.2 m
ISO 9001, FCC
7.3 cm
7.2 cm
3 cm
420 g
50 °C
0 - 90%
Customer reviews
Write a review for the Edimax 2-Port PS2 KVM with audio - Connects to PC with USB port here!
Edimax 2-port KVM Switch
Reviewed by John. Review Posted 02/06/2008
I have used this device for 12 months, I find very useful when using 2 PC's, sometimes the 2nd PC won't work correctly when first connected because drivers have not been found, but works after unplugging USB connector and re-connecting.
Very good device.
  • Overall 5*
  • Ease of use 4*
  • Value for money 5*
pretty basic but works ok
Reviewed by Anonymous Review Posted 18/06/2008
Very easy to setup and use. The only problem is that hitting ctrl key twice will switch computers. There is no way to change that or turn it off.
You would be surprised at how often you are in the middle of working and the KVM catches 2xCTRL key and switches computer. You then have to switch back and wait 20 seconds for the USB to get recognised on the original PC. Exceedingly annoying.
I'm sure this KVM is gerat for PCs that are not often used (eg a couple of servers), but don't use it on a normal desktop PC.
  • Overall 3*
  • Ease of use 5*
  • Value for money 3*
poor choice of title
Reviewed by Anonymous Review Posted 07/02/2008
Only takes PS2 mouse/keyboard and won't take USB. Even with USB->PS2 adapter fitted it won't recognise them.
This is despite mentioning USB in the product title. USB is only used to go from the splitter to the computers. it won't recognise USB input.
  • Overall 2*
  • Ease of use 2*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
