This combo print server allows you to share your GDI printer to all PCs through the network. GDI printers, run in Windows Graphical Device Interface (GDI) protocol. Sometimes GDI printers are called host-based printers because they rely on the host computer (Win2000/XP/Vista) to rasterize pages to an image format, not PostScript or PCL language. Therefore, almost none of Print Servers in the market can support GDI printers. PS-1216U implements a special technology which allows it to communicate with the GDI printer as if it is connected directly to your computer. With the feature, the GDI printer becomes a shared device easily.
Shares your GDI/host-based printers
This combo print server allows you to share your GDI printer to all PCs through the network. GDI printers, run in Windows Graphical Device Interface (GDI) protocol. Sometimes GDI printers are called host-based printers because they rely on the host computer (Win2000/XP/Vista) to rasterize pages to an image format, not PostScript or PCL language. Therefore, almost none of Print Servers in the market can support GDI printers. PS-1216U implements a special technology which allows it to communicate with the GDI printer as if it is connected directly to your computer. With the feature, the GDI printer becomes a shared device easily. -
Easy installation and configuration (with Web-based configuration) and fault tolerant upgrades
PS-1216 easy-to-use Windows installation wizard allows quick installation and setup. The print server can also be conveniently configured from any network client with a web-browser. Users don't have to worry about errors occurring in the midst of an upgrade, thus preventing the print server from operating. The print server's fault-tolerant upgrade function resumes the upgrade should problems occur during the initial upgrade.
- Edimax PS-1216U - print server - USB 2.0 - 10/100 Ethernet
- Print server
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- 10/100 Ethernet
- 5.8 cm x 7.5 cm x 2 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- TCP/IP
- RAM
- 2 MB
- Designed For
- BenQ CM 3000; Canon FAXPHONE L120; ImageCLASS MPC 190; PIXMA MP530; Epson EPL 6200L; HP Color LaserJet CP1215; LaserJet 1000, 1020, 1022, M1120, P1006, P1505, P2015; Lexmark P6250, X2350, X3350, X3470, X5470, X6170, X7170, X7350, Z603, Z617, Z645, Z735
- Print server
- Form Factor
- External
- USB 2.0
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- TCP/IP
- DHCP support, auto-uplink (auto MDI/MDI-X)
Processor / Memory
- RAM
- 2 MB
- Flash Memory
- 512 KB
- 1 x 100Base-TX - RJ-45
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- C-Tick, FCC
- Power Device
- Power adapter - external
- 5.8 cm
- 7.5 cm
- 2 cm
- 0 °C
- 55 °C
- 10 - 90%
- Designed For
- BenQ CM 3000 , Canon FAXPHONE L120 , Canon ImageCLASS MPC 190 , Canon PIXMA MP530 , Epson EPL 6200L , HP Color LaserJet CP1215 , HP LaserJet 1000, 1020, 1022, M1120 MFP, P1006, P1505, P2015 , Lexmark P6250, X2350, X3350, X3470, X5470, X5470 Business Edition, X6170, X7170, X7170 Business Edition, X7350, X7350 Business Edition, Z603 Color Jetprinter, Z617, Z645, Z735
