Edimax 1P 10/100Mbps Print server USB
Quicklinx: C2S1WS00 Mfr#: PS-1206U
The print server's easy-to-use windows installation wizard allows for quick installation and setup the print server. The print server can also be conveniently configured from any network client that supports web browsing.
Supports both Peer-to-Peer and Server-based printing. LAN clients can connect directly with the print server to execute printing jobs (Peer-to-Peer printing); or clients can send print jobs first to a server (queuing jobs) and allow the server to connect with the print server to execute the printing jobs (Server-based printing).
The print server provides LPR, IPP, SMB/TCP, Raw Printing and UNIX Logical Printer printing methods. You can choose the best printing method according to your environment.
The print server is compatible with all major operating systems used today.
The printer server can act as a DHCP server, allowing your LAN clients to automatically obtain an IP address or it can act as a DHCP client allowing for easy integration to your existing network.
This print server is compatible with the majority of HP, EPSON, Lexmark, Canon, Brother, Konica Minolta etc. MFPs and Printers.
  • Provides completed printing methods
    PS-1206U can support LPR, IPP, Raw Printing and UNIX Logical Printer printing methods. You can choose the best printing method according to your environment.
  • Supports major network protocols
    PS-1206U is a print server to share a USB printer to all network users. It supports TCP/IP, NetBEUI, Linux and MAC network protocol.
  • Easy installation and configuration (with web-based configuration)
    The print server's easy-to-use windows installation wizard allows a quick installation to setup PS-1206U. It can also be conveniently configured from any network client that support web-browsing.
  • Fault-tolerant firmware upgrades
    Users need not to worry about errors occurring during an upgrade, thus preventing PS-1206U from operating. PS-1206U fault-tolerant upgrade function allows to resume upgrading should problems occur during the initial upgrade.
Edimax PS-1206U - print server - USB 2.0 - 10/100 Ethernet
Print server
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
5.8 cm x 7.5 cm x 2 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, NetBEUI/NetBIOS, LPR/LPD
RAM
2 MB
IEEE 802.3, IEEE 802.3u
UNIX, Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/NT/2000/XP, Novell NetWare 3.x or later
Print server
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Remote Management Protocol
IPP, HTTP
DHCP support, auto-uplink (auto MDI/MDI-X), manageable, firmware upgradable
Processor / Memory
RAM
2 MB
Flash Memory
512 KB
1 x 100Base-TX - RJ-45
1 x USB 2.0 - 4 pin USB Type A
FCC Class B certified, C-Tick, ISO 9001
Power adapter - external
5.8 cm
7.5 cm
2 cm
55 °C
10 - 90%
