The Powerware 5110 uninterruptible power system (UPS) was designed to provide the best UPS power protection against the threats that lurk in public utilities. This line-interactive UPS system delivers the ultimate in power quality, constantly safeguarding your equipment from power outages, surges, sags, brownouts, and over-voltage conditions - while also providing varying degrees of power management for additional threats. If utility power is interrupted, even briefly, the Powerware 5110 transfers to UPS battery power.
- Eaton 5110 - UPS - 600 Watt - 1000 VA
- UPS - external
- 12 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V + 10% / - 10%
- Power Capacity
- 600 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 4 x power IEC 60320 C13 (surge) , 4 x power IEC 60320 C13 (UPS and surge)
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Run Time (Up To)
- 3 min at full load
- Networking
- USB
- Black
- 8.7 cm x 38.4 cm x 27 cm
- 3-year warranty with product registration
- UPS - external
- Battery Enclosure Type
- Internal
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 178 - 275 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V + 10% / - 10% - 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11 - 1 input line / 1 output line
- Surge Suppression
- Surge Energy Rating
- 476 Joules
- Circuit Protection
- Circuit breaker
- Efficiency
- 95%
- Technology
- Lead Acid
- Run Time (Up To)
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- Power cable - integrated - 1.8 m , 2 x power cable - external , USB cable - external , Phone cable - external
- Audible alarm, Automatic Voltage Regulation (AVR), LED indicators
- Plug and Play, FCC Class B certified, UL 1778, UL 497A, EN55022 Class B, EMC, CSA C22.2 No. 107.1, RoHS, EN 62040-1-1, EN 62040-2
- Software Included
- Eaton LANSafe
- Limited warranty - parts and labour - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 40 dB
- 8.7 cm
- 38.4 cm
- 27 cm
- 12 kg
