Eaton ePDU SW 0U (309 16A 3P) 21XC13:3XC19
Quicklinx: CBDDWS00 Mfr#: ESWB20
£1,086.34 ex VAT
£1,303.60 inc VAT
Designed for data centers needing remote site management, the Switched ePDU provides remote power monitoring of both voltage and current. The current is also displayed on a local two-digit current meter. The control interface is highly customizable with multiple functions and flexibility to send either SNMP traps or e-mail alerts.
  • Efficient power distribution
    The Eaton ePDU Switched model is designed for efficient power distribution, ensuring your PC and other devices remain powered with reliability.
  • Remote management capability
    Equipped with an RS-232 remote management interface, this power distribution unit allows for convenient remote management, enabling adjustments and monitoring without physical presence.
Eaton ePDU Switched - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
Input Wiring
3-phase
Input Connectors
1 x power IEC 60309 16A
Output connectors
21 x power IEC 60320 C13 ¦ 3 x power IEC 60320 C19
Ethernet 10/100, RS-232
5.2 cm x 5.3 cm x 160.4 cm
Height (Rack Units)
0U
Input Wiring
3-phase
Input Connectors
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) - RJ-45 , 1 x cascading - RJ-45 , 1 x USB - 4 pin USB Type A
Power cable - integrated
LCD display, voltage monitoring, current meter, vertical orientation, firmware upgradable
60 °C
5.2 cm
5.3 cm
160.4 cm
Brand: Eaton
Price Range Ex VAT: £1000 - £1500
