Eaton ePDU Metered Input - IEC60309 32A 1P Output 20XC13:2XC19:2XG
Quicklinx: CBD9WS00 Mfr#: EMIB18
£472.77 ex VAT
£567.32 inc VAT
New ePDU G3 Metered Input models feature best in class technologies, including ±1% billing grade accuracy, an advanced LCD pixel display, a hot-swap meter and the ability to daisy chain four ePDUs to share the same network connection and IP address.
Eaton ePDU G3 Metered Input - power distribution unit - 7 kW
Power distribution unit - rack-mountable
Rack Size
26U
Input Voltage
AC 230 V
Output Voltage
AC 200-240 V
Power Capacity
7 kW
Input Connectors
1 x power IEC 60309 32A
Output connectors
20 x power IEC 60320 C13 , 2 x power IEC 60320 C19 , 2 x power CEE 7/4
Ethernet, RS-232
5.2 cm x 5.3 cm x 115.4 cm
Height (Rack Units)
26U
Input Voltage
AC 230 V
Input Voltage Range
AC 200 - 240 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 200-240 V 50/60 Hz
Max Electric Current
32 A
Power Capacity
7 kW
Circuit Protection
Circuit breaker
Remote Management Interface
Ethernet, RS-232
1 x monitoring , 1 x management (Ethernet) , 1 x management (RS-232)
LED display, voltage monitoring, current meter
CB
60 °C
5.2 cm
5.3 cm
115.4 cm
Brand: Eaton
