New ePDU G3 Metered Input models feature best in class technologies, including ±1% billing grade accuracy, an advanced LCD pixel display, a hot-swap meter and the ability to daisy chain four ePDUs to share the same network connection and IP address.
- Eaton ePDU G3 Metered Input - power distribution unit - 7 kW
- Power distribution unit - rack-mountable
- Rack Size
- 26U
- Localisation
- France
- Input Voltage
- AC 230 V
- Output Voltage
- AC 200-240 V
- Power Capacity
- 7 kW
- Input Connectors
- 1 x power IEC 60309 32A
- Output connectors
- 20 x power IEC 60320 C13 , 2 x power IEC 60320 C19 , 2 x power CEE 7/5
- Networking
- Ethernet 10/100, RS-232
- Black
- 5.2 cm x 5.3 cm x 115.4 cm
- Height (Rack Units)
- 26U
- Black
- Localisation
- France
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 200 - 240 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 200-240 V 50/60 Hz
- Max Electric Current
- 32 A
- Power Capacity
- 7 kW
- Circuit Protection
- Circuit breaker
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x cascading - RJ-45
- Cables Included
- Power cable - integrated - 3 m
- Low-profile, LCD display, voltage monitoring, current meter, vertical orientation
- CB
- 0 °C
- 60 °C
- 5.2 cm
- 5.3 cm
- 115.4 cm
