New ePDU G3 In Line Metered Input models upgrade existing basic installation to include, including ±1% billing grade accuracy, an advanced LCD pixel display, a hotswap meter and the ability to daisy chain four ePDUs to share the same network connection and IP address
Operate in extreme environments
The ePDU G3 can be used in 60°C environments and containment solutions. -
True IEC Class 1 billing grade accuracy
Monitor your energy consumption (kWhr) plus V, W and A extremely accurately. Monitor ePDU and branch circuit. -
Prevent accidental disconnect
Integrated IEC outlet grip plug retention. Prevents accidental disconnect from being bumped or from vibration. -
Simplify load balancing
Color coding and laser engraved chassis easily link breakers to outlet groups. -
Reduce the IP ports needed to monitor your power
Daisy-chain up to 4 ePDUs to reduce the cost of networking. Reduces network infrastructure cost by 75%. -
Centrally monitor and manage
Easily monitor the status of your power distribution. -
Easily access hot swappable IT equipment
The ePDU doesn't protrude into the rack and is low profile even at the breakers.
 - Eaton ePDU G3 In-Line Monitored - power monitoring unit - 22 kW
 - Power monitoring unit - rack-mountable
- Rack Size
 - 0U
- Input Wiring
 - 3-phase
- Input Voltage
 - AC 400 V
- Output Voltage
 - AC 400 V
- Power Capacity
 - 22 kW
- Input Connectors
 - 1 x power IEC 60309 32A
- Output connectors
- Networking
 - Ethernet, RS-232
 - Black
 - 44.3 cm x 5.3 cm x 5.2 cm
- Height (Rack Units)
 - 0U
 - Black
- Input Voltage
 - AC 400 V
- Input Voltage Range
 - AC 346 - 415 V
- Frequency Provided
 - 50/60 Hz
- Input Wiring
 - 3-phase
- Frequency Required
 - 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
 - AC 400 V 50/60 Hz
- Max Electric Current
 - 32 A
- Power Capacity
 - 22 kW
- Remote Management Interface
 - Ethernet, RS-232
 - 1 x monitoring , 1 x management (Ethernet) , 1 x management (RS-232)
- Cables Included
 - 2 x power cable - integrated - 3 m
 - LED display, voltage monitoring, current meter
 - CB
 - 0 °C
 - 60 °C
 - 44.3 cm
 - 5.3 cm
 - 5.2 cm
