Eaton ePDU In-Line Metered - IEC60309 16A 1P Output 1XIEC60389
Quicklinx: CBDSWS00 Mfr#: EILB13
Power Rating: 7kW
£322.59 ex VAT
£387.10 inc VAT
New ePDU G3 In Line Metered Input models upgrade existing basic installation to include, including ±1% billing grade accuracy, an advanced LCD pixel display, a hotswap meter and the ability to daisy chain four ePDUs to share the same network connection and IP address
  • Operate in extreme environments
    The ePDU G3 can be used in 60°C environments and containment solutions.
  • True IEC Class 1 billing grade accuracy
    Monitor your energy consumption (kWhr) plus V, W and A extremely accurately. Monitor ePDU and branch circuit.
  • Prevent accidental disconnect
    Integrated IEC outlet grip plug retention. Prevents accidental disconnect from being bumped or from vibration.
  • Simplify load balancing
    Color coding and laser engraved chassis easily link breakers to outlet groups.
  • Reduce the IP ports needed to monitor your power
    Daisy-chain up to 4 ePDUs to reduce the cost of networking. Reduces network infrastructure cost by 75%.
  • Centrally monitor and manage
    Easily monitor the status of your power distribution.
  • Easily access hot swappable IT equipment
    The ePDU doesn't protrude into the rack and is low profile even at the breakers.
Eaton ePDU G3 In-Line Monitored - power monitoring unit - 7 kW
Power monitoring unit - rack-mountable
Rack Size
0U
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
7 kW
Input Connectors
1 x power IEC 60309 16A
Output connectors
Ethernet, RS-232
44.3 cm x 5.3 cm x 5.2 cm
Height (Rack Units)
0U
Input Voltage
AC 230 V
Input Voltage Range
AC 200 - 240 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Max Electric Current
16 A
Power Capacity
7 kW
Remote Management Interface
Ethernet, RS-232
1 x monitoring , 1 x management (Ethernet) , 1 x management (RS-232)
2 x power cable - integrated - 3 m
LED display, voltage monitoring, current meter
CB
60 °C
44.3 cm
5.3 cm
5.2 cm
Power Rating: 7kW
Brand: Eaton
