Eaton Ellipse ECO 650 USB IEC UPS
Quicklinx: 7T2VWS00 Mfr#: EL650USBIEC
Type: UPS
Power Rating: 400Watt
Hurry, only 1 left in stock!
£103.79 ex VAT
£124.54 inc VAT
As well as providing a power supply backed up by a battery to keep equipment operating during a power failure, the Ellipse Eco also provides effective protection against damaging surges. The Eco Control function automatically disables peripherals when the master device is turned off in order to save up 25 % more energy compared to previous generation of UPS. This unit can either be placed horizontally, 19 inch rack mounted or wall mounted. The Ellipse Eco also includes the Eaton Intelligent Power Manager software. It is an ideal protection for all business computers.
  • Energy-efficient power protection for business computers
    With an efficient electrical design and the EcoControl function, which automatically disables peripherals when the master device is turned off, the Eaton Ellipse ECO helps you make energy savings of up to 25 percent compared to previous-generation UPSs. As well as providing a power supply backed up by a battery to keep equipment operating during a power failure, the Ellipse ECO also provides effective protection against damaging surges.
  • Easy integration and installation
    The Ellipse ECO's extra-flat design makes it easy to install in any office environment: installation options include vertical box format, below the desk, horizontally under a monitor and 19" rack-mounted.
  • Complete peace of mind
    Periodic battery self-test ensures early detection of a battery that needs to be replaced. Easy-to-replace battery helps to extend UPS service life. Push-button circuit breaker enables easy recovery from an overload or short circuit.
Eaton Ellipse ECO 650 USB IEC - UPS - 400 Watt - 650 VA
UPS - rack-mountable / external
Rack Size
19" - 2U
3.6 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V
Power Capacity
400 Watt / 650 VA
Input Connectors
1 x power
Output connectors
3 x power IEC 60320 (UPS and surge) , 1 x power IEC 60320 (surge)
Lead Acid
Run Time (Up To)
9 min at half load
USB
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7
8.1 cm x 23.5 cm x 26.3 cm
Height (Rack Units)
2U
Rack Size
19"
UPS Technology
Off-line
Input Voltage
AC 230 V
Input Voltage Range
AC 184 - 264 V
Input Voltage Range (Adjustable)
AC 161 - 284 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power
Output Voltage
AC 220/230/240 V 50/60 Hz
Power Capacity
400 Watt / 650 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Surge Suppression
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
9 min at half load , 6 min at 70% load
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
USB cable - external
Rack Mounting Kit
Optional
Wall mountable, audible alarm, LED indicators, deep discharge protection, cold-start function, Eco-efficiency
CB, IEC 62040-1-1, IEC 62040-2, IEC 60950-1, IEC 61643-1
Software Included
8.1 cm
23.5 cm
26.3 cm
3.6 kg
Type: UPS
Brand: Eaton
Stock Status: In stock
