Eaton Ellipse ECO 650 IEC UPS
Quicklinx: 7T2TWS00 Mfr#: EL650IEC
Type: UPS
Power Rating: 400watt
£93.55 ex VAT
£112.26 inc VAT
As well as providing a power supply backed up by a battery to keep equipment operating during a power failure, the Ellipse Eco also provides effective protection against damaging surges. The Eco Control function automatically disables peripherals when the master device is turned off in order to save up 25 % more energy compared to previous generation of UPS. This unit can either be placed horizontally, 19 inch rack mounted or wall mounted. The Ellipse Eco also includes the Eaton Intelligent Power Manager software. It is an ideal protection for all business computers.
Eaton Ellipse ECO 650 IEC - UPS - 400 Watt - 650 VA
UPS - rack-mountable / external
Rack Size
19" - 2U
3.6 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V
Power Capacity
400 Watt / 650 VA
Input Connectors
1 x power
Output connectors
3 x power IEC 60320 (UPS and surge) , 1 x power IEC 60320 (surge)
Lead Acid
Run Time (Up To)
9 min at half load
8.1 cm x 23.5 cm x 26.3 cm
Height (Rack Units)
2U
Rack Size
19"
UPS Technology
Off-line
Input Voltage
AC 230 V
Input Voltage Range
AC 184 - 264 V
Input Voltage Range (Adjustable)
AC 161 - 284 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power
Output Voltage
AC 220/230/240 V 50/60 Hz
Power Capacity
400 Watt / 650 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Surge Suppression
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
9 min at half load , 6 min at 70% load
Rack Mounting Kit
Optional
Wall mountable, audible alarm, LED indicators, deep discharge protection, cold-start function
CB, IEC 62040-1-1, IEC 62040-2, IEC 60950-1, IEC 61643-1
8.1 cm
23.5 cm
26.3 cm
3.6 kg
Type: UPS
Brand: Eaton
