As well as providing a power supply backed up by a battery to keep equipment operating during a power failure, the Ellipse Eco also provides effective protection against damaging surges. The Eco Control function automatically disables peripherals when the master device is turned off in order to save up 25 % more energy compared to previous generation of UPS. This unit can either be placed horizontally, 19 inch rack mounted or wall mounted. The Ellipse Eco also includes the Eaton Intelligent Power Manager software. It is an ideal protection for all business computers.
- Eaton Ellipse ECO 500 IEC - UPS - 300 Watt - 500 VA
- UPS - rack-mountable / external
- Rack Size
- 19" - 2U
- 2.9 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V
- Power Capacity
- 300 Watt / 500 VA
- Input Connectors
- 1 x power
- Output connectors
- 3 x power IEC 60320 (UPS and surge) , 1 x power IEC 60320 (surge)
- Battery
- Lead Acid
- Run Time (Up To)
- 9 min at half load
- 8.1 cm x 23.5 cm x 26.3 cm
- 2-year warranty
- Height (Rack Units)
- 2U
- Rack Size
- 19"
- UPS Technology
- Off-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 184 - 264 V
- Input Voltage Range (Adjustable)
- AC 161 - 284 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V 50/60 Hz
- Power Capacity
- 300 Watt / 500 VA
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 9 min at half load , 5 min at 70% load
- Rack Mounting Kit
- Optional
- Wall mountable, audible alarm, LED indicators, deep discharge protection, cold-start function
- CB, IEC 62040-1-1, IEC 62040-2, IEC 60950-1, IEC 61643-1
- Limited warranty - 2 years
- 8.1 cm
- 23.5 cm
- 26.3 cm
- 2.9 kg
