As well as providing a power supply backed up by a battery to keep equipment operating during a power failure, the Ellipse Eco also provides effective protection against damaging surges. The Eco Control function automatically disables peripherals when the master device is turned off in order to save up 25 % more energy compared to previous generation of UPS. This unit can either be placed horizontally, 19 inch rack mounted or wall mounted. The Ellipse Eco also includes the Eaton Intelligent Power Manager software. It is an ideal protection for all business computers.
- Eaton Ellipse ECO 1200 USB IEC - UPS - 750 watt - 1200 VA
- UPS - rack-mountable / external
- Rack Size
- 19" - 2U
- 6.7 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V
- Power Capacity
- 750 watt / 1200 VA
- Input Connectors
- 1 x power
- Output connectors
- 4 x power IEC 60320 (UPS and surge) , 4 x power IEC 60320 (surge)
- Battery
- Lead Acid
- Run Time (Up To)
- 10 min at half load
- Networking
- USB
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7
- 8.1 cm x 31.2 cm x 30.5 cm
- 2-year warranty
- Height (Rack Units)
- 2U
- Rack Size
- 19"
- UPS Technology
- Off-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 184 - 264 V
- Input Voltage Range (Adjustable)
- AC 161 - 284 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 10 min at half load , 6 min at 70% load
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- USB cable - external
- Rack Mounting Kit
- Optional
- Wall mountable, audible alarm, LED indicators, deep discharge protection, cold-start function, Eco-efficiency
- CB, IEC 62040-1-1, IEC 62040-2, IEC 60950-1, IEC 61643-1
- Software Included
- Intelligent Power Manager
- OS Required
- Limited warranty - 2 years
- 8.1 cm
- 31.2 cm
- 30.5 cm
- 6.7 kg
