The Eaton 9PX UPS provides energy efficient power protection for small & medium Datacenters, IT rooms and Infrastructure. Delivering double conversion protection with 40% less energy usage and 28% more power 9PX is the perfect UPS for IT and Facility managers that are concerned by energy cost and are looking for next generation power protection solutions.
Graphical LCD display
It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing. -
Availability and flexibility
The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems. -
Paralleling functionality
Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology! -
Load segment control
It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
- Eaton 9PX 9PX6KIBP - UPS - 5400 Watt - 6000 VA
- UPS - Power Factor Correction (PFC) - rack-mountable / external
- Rack Size
- 19" - 3U
- 48 kg
- Input Voltage
- AC 200/208/220/230/240 V
- Output Voltage
- AC 200/208/220/230/240 V ± 1%
- Power Capacity
- 5400 Watt / 6000 VA
- Input Connectors
- Hardwire
- Output connectors
- 3 x power IEC 60320 C13 , 2 x power IEC 60320 C19 , 1 x hardwire
- Battery
- Expandable
- Battery Form Factor
- Plug-in module
- Run Time (Up To)
- 3 min at full load
- Networking
- RS-232, USB
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2008
- 44 cm x 68.5 cm x 13 cm
- Environmental Standards
- ENERGY STAR
- 2-year warranty
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 3U
- Rack Size
- 19"
- UPS Technology
- On-line
- Supported Power Modules Qty
- 12
- Input Voltage
- Input Voltage Range
- AC 176 - 276 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Hardwire
- Power Output Connectors Details
- Output Voltage
- AC 200/208/220/230/240 V ± 1% - 50/60 Hz
- Power Capacity
- Surge Suppression
- Expandable
- Remote Management Interface
- RS-232, USB
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Advance Battery Management (ABM), LCD display, built-in maintenance bypass, LED indicators, deep discharge protection, automatic self-test
- FCC Class A certified, UL, TUV, UL 1778, CB, IEC 62040-3, IEC 62040-1-1, IEC 62040-2, CSA 22.2, EN 62040-1-1, EN 62040-2
- Software Included
- Intelligent Power Software Suite
- OS Required
Sustainability Information
- ENERGY STAR
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Sound Emission
- 45 dBA
- 44 cm
- 68.5 cm
- 13 cm
- 48 kg
Eaton 9PX EBM 180V 5kVA & 6kVA | In Stock | £1,126.80 |
