Eaton 9PX 6000i HotSwap (6000VA/5400W)
Quicklinx: CBN4WS00 Mfr#: 9PX6KiBP
Power Rating: 5400Watt
£2,482.34 ex VAT
£2,978.80 inc VAT
The Eaton 9PX UPS provides energy efficient power protection for small & medium Datacenters, IT rooms and Infrastructure. Delivering double conversion protection with 40% less energy usage and 28% more power 9PX is the perfect UPS for IT and Facility managers that are concerned by energy cost and are looking for next generation power protection solutions.
  • Graphical LCD display
    It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing.
  • Availability and flexibility
    The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems.
  • Paralleling functionality
    Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology!
  • Load segment control
    It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
Eaton 9PX 9PX6KIBP - UPS - 5400 Watt - 6000 VA
UPS - Power Factor Correction (PFC) - rack-mountable / external
Rack Size
19" - 3U
48 kg
Input Voltage
AC 200/208/220/230/240 V
Output Voltage
AC 200/208/220/230/240 V ± 1%
Power Capacity
5400 Watt / 6000 VA
Input Connectors
Hardwire
Output connectors
3 x power IEC 60320 C13 , 2 x power IEC 60320 C19 , 1 x hardwire
Expandable
Battery Form Factor
Plug-in module
Run Time (Up To)
3 min at full load
RS-232, USB
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2008
44 cm x 68.5 cm x 13 cm
Environmental Standards
ENERGY STAR
Battery Enclosure Type
Plug-in module
Height (Rack Units)
3U
Rack Size
19"
UPS Technology
On-line
Supported Power Modules Qty
12
Input Voltage
Input Voltage Range
AC 176 - 276 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Hardwire
Output Voltage
AC 200/208/220/230/240 V ± 1% - 50/60 Hz
Power Capacity
5400 Watt / 6000 VA
Surge Suppression
Expandable
Remote Management Interface
RS-232, USB
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Advance Battery Management (ABM), LCD display, built-in maintenance bypass, LED indicators, deep discharge protection, automatic self-test
FCC Class A certified, UL, TUV, UL 1778, CB, IEC 62040-3, IEC 62040-1-1, IEC 62040-2, CSA 22.2, EN 62040-1-1, EN 62040-2
Software Included
Intelligent Power Software Suite
Sustainability Information
ENERGY STAR
Sound Emission
45 dBA
44 cm
68.5 cm
13 cm
48 kg
CBN4 Eaton 9PX EBM 180V 5kVA & 6kVA In Stock £1,126.80
Brand: Eaton
Price Range Ex VAT: £1500+
