The Eaton 9PX UPS provides energy-efficient power protection for small & medium Datacenters, IT rooms and Infrastructure. Delivering double conversion protection with 40% less energy usage and 28% more power 9PX is the perfect UPS for IT and Facility managers that are concerned by energy cost and are looking for next generation power protection solutions.
Graphical LCD display
It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing. -
Availability and flexibility
The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems. -
Paralleling functionality
Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology! -
Load segment control
It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
- Eaton 9PX 3000i RT2U - UPS - 3000 watt - 3000 VA
- UPS - Power Factor Correction (PFC) - rack-mountable / external
- Rack Size
- 2U
- 27.6 kg
- Input Wiring
- 1-phase
- Input Voltage
- AC 200/208/220/230/240 V
- Output Voltage
- Power Capacity
- 3000 watt / 3000 VA
- Input Connectors
- 1
- Output connectors
- 8 x power IEC 60320 C13 , 2 x power IEC 60320 C19 16A
- Networking
- RS-232, USB
- 44 cm x 60.5 cm x 8.65 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- Height (Rack Units)
- 2U
- UPS Technology
- On-line
- Input Voltage
- Input Voltage Range
- AC 176 - 276 V
- Input Wiring
- 1-phase
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- Power Capacity
- Efficiency
- 98%
- Run Time (Up To)
- 60 min at 300 Watts , 36 min at 500 Watts , 23 min at 800 Watts , 13 min at 1200 Watts , 7 min at 1800 Watts , 4 min at 2500 Watts
- Remote Management Interface
- RS-232, USB
- 1 x management (USB) , 1 x management (RS-232)
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- LCD display, internal bypass
- FCC Class B certified, TUV, CISPR 22 Class B, UL 1778, CB, IEC 62040-2, cULus, CSA 22.2, KC, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
- Software Included
- Intelligent Power Software Suite
Sustainability Information
- ENERGY STAR
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- Sound Emission
- 40 dB
- 44 cm
- 60.5 cm
- 8.65 cm
- 27.6 kg
