Eaton 9PX 3000i RT2U
Quicklinx: CBQ3WS00 Mfr#: 9PX3000IRT2U
Power Rating: 3000watt
£2,286.97 ex VAT
£2,744.36 inc VAT
The Eaton 9PX UPS provides energy-efficient power protection for small & medium Datacenters, IT rooms and Infrastructure. Delivering double conversion protection with 40% less energy usage and 28% more power 9PX is the perfect UPS for IT and Facility managers that are concerned by energy cost and are looking for next generation power protection solutions.
  • Graphical LCD display
    It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing.
  • Availability and flexibility
    The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems.
  • Paralleling functionality
    Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology!
  • Load segment control
    It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
Eaton 9PX 3000i RT2U - UPS - 3000 Watt - 3000 VA
UPS - Power Factor Correction (PFC) - rack-mountable / external
Rack Size
2U
27.6 kg
Input Wiring
1-phase
Input Voltage
AC 200/208/220/230/240 V
Output Voltage
Power Capacity
3000 Watt / 3000 VA
Input Connectors
1
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19 16A
RS-232, USB
44 cm x 60.5 cm x 8.65 cm
Environmental Standards
ENERGY STAR
3-year warranty
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
Input Voltage Range
AC 176 - 276 V
Input Wiring
1-phase
Frequency Required
40 - 70 Hz
Input Connectors
1
Output Voltage
Power Capacity
3000 Watt / 3000 VA
Efficiency
98%
Run Time (Up To)
60 min at 300 Watts , 36 min at 500 Watts , 23 min at 800 Watts , 13 min at 1200 Watts , 7 min at 1800 Watts , 4 min at 2500 Watts
Remote Management Interface
RS-232, USB
1 x management (USB) , 1 x management (RS-232)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
LCD display, internal bypass
FCC Class B certified, TUV, CISPR 22 Class B, UL 1778, CB, IEC 62040-2, cULus, CSA 22.2, KC, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
Intelligent Power Software Suite
Sustainability Information
ENERGY STAR
Limited warranty - 3 years , Limited warranty - batteries - 2 years
Sound Emission
40 dB
44 cm
60.5 cm
8.65 cm
27.6 kg
Brand: Eaton
Price Range Ex VAT: £1500+
