Dynamode DH-660 USB Stereo Headset
Customer rating: 5.0* (Write a review)
Quicklinx: 4RLPWS00 Mfr#: DH-660-USB
Yes that's right! The new DH-660-USB from Dynamode is a full Skype compatible USB-powered Stereo Headphone with adjustable boom microphone.
Simply plug the DH-660-USB into any USB port on a laptop or PC and enjoy rich, high-quality sound and is perfect for almost any application.
The DH-660-USB now comes with an in-line remote control to allow full adjustment of common audio functions without touching your computer.
Rounding off this feature packed product is a comfortable over-the-head design with fully adjustable boom microphone.
Dynamode DH-660-USB - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 105 dB
Microphone
Boom
Headset - wired
Recommended Use
Computer
Audio Output
Full size binaural
Wired
Sound Output Mode
Stereo
Sensitivity
105 dB
In-Cord Volume Control
Microphone
Boom
Sensitivity
-58 dB
Connector Type
USB (4 PIN USB Type A)
Cable Details
Headset cable - 1.9 m
Customer reviews
Write a review for the Dynamode DH-660 USB Stereo Headset here!
Very good headset
Reviewed by Gordon. Review Posted 08/02/2009
I had to do some homework because Dabs use to non-Windows users is very lacking. The spec sheet on the manufacturers website claims it works with Windows, OSX and Linux. It works like a charm on Linux. The sound is fine, build quality is fine, but my only concern in the microphone bendy steel wire; it's solidly built but it's not easy to flip it up for storage then down the exact same position next time; which means you have to do sound checks each time to make sure the volume is right. Apart from that, it's a great USB mic and headset and fantastic value for money.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Good buy
Reviewed by Pablo. Review Posted 13/02/2009
I needed USB headset for my laptop and this was the cheapest I could find. However the quality is superb and it does work flawlessly both with Vista and my Ubuntu linux which makes me more than happy with this product.
  • Overall 5*
  • Ease of use 5*
Fantastic!
Reviewed by Emily. Review Posted 03/10/2008
Really pleased with this headset!
Inexpencive - Great audio quality and great mic!
Would highly reccomend!
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
