Dynamode has established itself as one of the leading companies in its field of technology on the world markets. Dynamode has kept an edge over its competitors by creating new solutions for a changing global market, never compromising its integrity, and quality of its user friendly products.
- Dynamode DH-660 - headset
- Product Type
- Headset - wired
- Headphones Form Factor
- Monaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 103 dB
- Impedance
- 32 Ohm
- Product Type
- Headset - wired
Audio Output
- Monaural
- Wired
- Sound Output Mode
- Mono
- 20 - 20000 Hz
- Sensitivity
- 103 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
Microphone
- Sensitivity
- -58 dB
- Connector Type
- Headset
- Cable Details
- Headset cable - 2.5 m
Customer reviews
Write a review for the Dynamode DH-660 PC Headset here!
Good Technology.. but flimsy
Reviewed by Antoneey. Review Posted 31/07/2008
Now I've been using this headset for a good 10 months now and I have to say, it has its ups and downs. The upside is that the microphone quality is good, the sound quality is pretty good, there's even bass in them too and they're comfortable enough (providing you wear them
for 4 hours or less).. the downside to them is that they can fall apart within 10 minutes of use if you dont treat them with utter care, and the reason you should take care of them is that they will treat your ear's to a good blast of harmful noises if you don't. The wire's in the adjustable Microphone somehow get a litle mixed up with the electrics for the sound inside the headset quite easily, yeah.. I learned the hard way. For the price though, you get what you pay for. I'd buy it just for the mic in future.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
