Get the perfect image. For less.
Are you looking to get the very most out of your latest Hi-Definition 3D LED/Plasma TV and BluRay™ setup but are put off due to the high cost of the HDMI connecting cables? Are you looking to extend your current HDMI cables or upgrade to the latest HDMI 1.4 specification?
Introducing the latest HDMI 1.4 specification cables from Dynamode. Offering not only the latest, high-speed connection rates of up to 8Gbps*, high-speed Ethernet which allows up to 100Mbps to be transmitted through the HDMI cable, thus removing the need for separate data cables from say the TV and the Home Theatre system together with Audio Return Channel (ARC) which again means Audio signals can again be sent concurrently through this highquality HDMI cable, again reducing separate cable clutter.
- Premium grade HDMI certified copper conductors
- Ideal for latest LED 3D TVs, BluRay™ Theatres etc
- HMDI Version 1.4 specification ~ up to 8Gbps*
- High-speed Ethernet Channel ~ up to 100Mbps*
- Audio Return Channel (ARC)*
- Deep Colour and xvYCC support for optimal image
- Triple-shielded cable for excellent signal quality
- Reduced EMI and RF noise across all frequencies
Experience incredible clarity for picture and sound
dependent on compatible devices, all speeds approximate
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
7KZR 041116 Condition: This item is new and unused. The packaging has been opened. |
£1.87 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
