Product
Brand
Dynamode 6 Way Horizontal 10A IEC Switched PDU / Power Bar > IEC Plug
Quicklinx: 8L4DWS00 Mfr#: PDU-6WS-H-IEC-IEC
Looking for high performance power distribution for your heavily loaded systems? Combining a fully certified IEC-14 plug input combined with a compatible heavy load power flex means you can be assured this PDU can work without problems, 24/7. Furthermore, incorporated onto the horizontal form-factor are industry standard IEC-13 sockets, ideal for data, telco and broadcast equipment with the added benefit of integral electrical surge protection. Robust in design, with an integral neon illuminated rocker switch for assured functionality, the PDU is designed to deliver maximum electrical power today and tomorrow.
