Dynabook Satellite Pro R40-C-14L Core i3-6006U 4GB 128GB SSD 14" Windows 10 Pro Academic 64-bit
Quicklinx: FGXPWS00 Mfr#: PS461E-0UV0EGEN
  • Core i3
  • Bluetooth 4.0
  • IEEE 802.11n
Give your business an edge with an enterprise-class laptop built for small- or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R40 will help meet all your computing needs without putting a big dent in your bottom line.
  • A professional device that just works
    The Satellite Pro R40-C is an entry-level device, designed to meet the demands of business professionals who need a dependability, and students who require a sturdy learning companion. Well-equipped with Intel Core architecture – and with the option to include Windows 10 Pro – users have all they need to be productive. And it's all backed up by Toshiba's 30 years of notebook development and innovation.
  • Stands up to the rest of daily use
    Designed to withstand the daily wear and tear of an education environment – or the demands of a busy office – the Satellite Pro R40-C offers longevity and reliability. Its 3D sensor helps to keep data protected at all times, and its robust chassis design has passed vigorous hinge testing to ensure sturdiness over a prolonged period of time.
  • Ergonomically designed for professional performance
    The Satellite Pro R40-C's full size keyboard delivers a professional typing experience for optimised productivity. Its silent functionality means it's easy to work discreetly in important meetings, quiet libraries or on crowded trains. And the non-CSV screen enables users to work indoors or outdoors – in both low light and bright light scenarios – without distraction.
  • Connects to all the essentials
    Users can enjoy full connectivity, without the need for any adapters, thanks to a selection of full-size ports including: HDMI, RGB, USB 3.0, Gigabit LAN and SD-card. The Satellite Pro R40-C also comes equipped with the latest wireless technologies, such as the Intel premium ac/abgn, Intel Wireless-Display and Bluetooth – meaning business professionals and students alike can always connect to everyone and everything they need to.
  • Balances quality and affordability
    Offering the right balance between high quality components – such as a reliable Intel Core architecture, Intel Premium Wi-Fi and Gigabit LAN – and affordable price points, the Satellite Pro R40-C is perfectly positioned for budget-conscious students and young business professionals. The device is also ideal for businesses with multiple orders to make – providing a reliable foundation for any office.
  • Compatible with an array of accessories
    The Satellite Pro R40-C has all the single plug-and-click connection points users need to connect to all kinds of peripherals and displays. This includes Toshiba's Dynadock and storage range – which helps to make the device a comprehensive desktop companion. What's more, users can make the most of Toshiba's compatible bags and sleeves for carrying and protecting their device. *Accessories sold separately. Please check the range of accessories available at.
  • Optimises power consumption
    Users are able to stay in control of the Satellite Pro R40-C's power consumption, thanks to Toshiba's pre-installed Eco Utility software. In fact, the EPEAT certified device is eco-friendly in every aspect, also benefitting from the latest Energy Star qualification.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Satellite Pro R40-C-14L - 14" - Intel Core i3 - 6006U - 4 GB RAM - 128 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i3 (6th Gen) - 6006U / 2 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
128 GB SSD
Optical Drive
DVD SuperMulti
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 8 hours
3-axis accelerometer
Security
Trusted Platform Module (TPM 2.0) Security Chip
Graphite black, tile black (keyboard)
34.01 cm x 24.41 cm x 2.38 cm
1.75 kg
Region: United Kingdom, Ireland
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - pick-up and return - 1 year - carry-in
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i3 (6th Gen) 6006U / 2 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD M.2 SATA
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - HD
Resolution
0.9 Megapixel
Video Resolutions
1280 x 720
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, touchpad
Multi-gesture touch pad, Palm Rejection Technology
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8 hours
AC Adapter
Input
AC 120/230 V
Output
19 V, 2.37 A
Connections & Expansion
Interfaces Details
2 x USB 3.0 , Gigabit Ethernet , Headphone/microphone combo jack , HDMI , VGA , USB 3.0 (Sleep & Charge)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription)
Integrated Options
Security
Administrator password, system password, hard drive password
Theft/Intrusion Protection
Power adapter
Localization
1.75 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
