Dynabook Satellite Pro C50-E-102 Core i5-8250U 8GB 512GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: G0DLWS00 Mfr#: A1PYS20E111D
  • Core i5
  • IEEE 802.11n
IT budgets are strained but the pressure's still on to perform. What's more, appearances matter. That's why the 15" Satellite Pro C50 offers premium design, fully-loaded features and seamless performance at a remarkably low price. With a powerful Intel Core Processor, 8GB of DDR4 RAM, lightning-fast SSD storage and the latest USB Type-C port for one-click connection to your favourite peripherals, this slimline, narrow-bezel laptop is ready to take on any business task you throw its way, and do so in style.
  • No-compromise style, productivity and value
    Meet your company's technology goals and your IT budget with a stylish device you'll be proud to use. The Satellite Pro C50 is equipped with a powerful Intel Core Processor, 8GB of DDR4 RAM, the latest USB Type-C port for one-click connection to your favourite peripherals and features a special anti-bacterial paint coating which inhibits the growth of microorganisms such as bacteria. And although it's Dynabook's most affordable laptop, you can rest assured that it's just as carefully engineered and reliable as all our devices.
  • Designed to look the part
    Entry-level price, executive looks. The sleek, dark blue Satellite Pro C50 is just 19.7mm thin and weighs only 1.76kg. Its 15.6" non-glare FHD screen takes up more than 80% of its upper surface, affording the device a compact footprint. Yet it remains a pleasure to use at the desk or on the road thanks to its ergonomic keyboard, full numeric keypad and 12.5-hour battery life*. It also features the largest ClickPad in Dynabook's portfolio, supporting Precision Touch Pad technology for accurate control, no mouse required. * measured with Mobile Mark 2014. Mobile Mark is a trademark of Business Applications Performance Corporation.
  • Makes any environment your workspace
    It may be compact, but the Dynabook Satellite Pro C50 is fully loaded with connectivity. Its USB Type-C 3.1 port supports charging, external display and data transfer, all at once via the Dynabook USB-C dock optional accessory. Meanwhile, an HDMI 1.4 port provides easy sharing on external screens, and fast and reliable Gigabit LAN and 802.11ac Wi-Fi enable effortless network access. And if you need to quickly swap files or connect peripherals, its SD card reader, pair of USB Type-A ports and built-in Bluetooth 4.2 have you covered.
  • Be there without going there
    Seamless communication with customers and colleagues is more important than ever. The Satellite Pro C50 is ready for action in this regard. It comes with everything you need to video conference, including an HD webcam, Microsoft Cortana-enabled microphone and stereo speakers. Or if you prefer, you can connect up a headset via the laptop's Bluetooth or mic/headphone combination socket.
  • Security you can trust
    Peace of mind comes as standard with the Satellite Pro C50. Enterprise-ready security features such as firmware-based Trusted Platform Module (TPM) 2.0 and user and administrator password access help keep valuable data out of the wrong hands, while the built-in Kensington Lock Slot ensures the laptop stays right where you left it.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Satellite Pro C50-E-102 - 15.6" - Intel Core i5 - 8250U - 8 GB RAM - 512 GB SSD
Notebook
Operating System
Windows 10 Home
Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
512 GB SSD
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.2, Gigabit Ethernet
2-cell - up to 12.75 hours
Security
Firmware Trusted Platform Module (TPM) Security Chip
Dark blue, tile black (keyboard)
36.25 cm x 24.05 cm x 1.97 cm
1.76 kg
0.33 W/kg
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8250U / 1.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
RAM
8 GB (2 x 4 GB)
Max RAM Supported
8 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
Storage
Main Storage
512 GB SSD M.2 SATA
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-reflective, Full HD eDP
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers
Input
Keyboard, ClickPad
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
2-cell Lithium Ion
Run Time
Up to 12.75 hours
AC Adapter
Input
Output
19 V, 2.1 A
Connections & Expansion
Interfaces Details
USB 3.0 , USB 3.0 (Sleep & Charge) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery/data/video) , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft 365 (30 days trial)
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
SAR Value
0.33 W/kg
0.33 W/kg
1.76 kg
Sustainability Information
TCO Certified
