Designed specifically for use in education and for small and medium businesses, the Satellite Pro range offers affordable and reliable devices, which provide increased productivity and efficiency whether working in the classroom, office or on the move.
Desk-based excellence
With the Satellite Pro A40-D's full-size keyboard, you can type documents or communicate with colleagues silently and precisely. And when it comes to reviewing creative work, the full-size, non-CSV HD or Full HD display delivers you vibrant clarity, even in bright sunlight – so you'll never need an external monitor. You can even choose the drive that suits you – whether it's a traditional Hard Disc Drive (HDD) or a Solid State Drive (SSD) – so you get to make the right choice between speed and storage capacity. -
Mobile brilliance
The easy to carry, 35.56 cm (14") Satellite Pro A40-D makes working on the move just as productive as being at your desk. Get things done outside with the optional high brightness, non-reflective IPS panel, and connect quickly and easily wherever you are using built in best-in-class Intel Wi-Fi. With a range of full size ports and Intel WiDi, you can connect, collect, share and store information with ease in any business situation – whether you're presenting at a client's office, or working in the library. -
The security business needs
Designed to be super-accessible in the right hands, and super-secure in the wrong ones, the Satellite Pro A40-D combines outstanding usability with exceptional security features. With its optional SSD, the A40-D boots up and hibernates as quickly as you need it to – so it's always ready to go. And because you can set the A40-D to require both your fingerprint and smartcard to log in, the laptop offers extra security with convenience too. -
Work freely with confidence
With H.A.L.T. (Highly Accelerated Life Test) performed by the independent institute, TÜV Rheinland, you can be sure that your Satellite Pro A40-D is built to last - even taking into account the bumps and scrapes that come with agile working. -
Investment protection
The Satellite Pro A40-D is a device you can rely on, from a partner you can trust. Toshiba understands the demands of daily work. With 30 years of notebook development, we are able to assure customers of quality that's built to last. -
All the accessories you need
The Satellite Pro A40-D is available with a selection of accessories that make agile working simpler. Discover our Dynadock range – which adds to your display and connectivity options in an instant – or get USB sticks and SD cards for quick, simple data transfer. We also have stylish laptop bags and sleeves, so you can protect your PC on the move. *Accessories sold separately. Please check the range of accessories available at. -
Certified Eco-friendly
Take control of your environmental impact with Toshiba's EPEAT certified Satellite Pro A40-D, complete with built-in Eco Utility. Quickly and easily customise your computer settings to maximise power efficiency, minimise energy consumption, and reduce the impact your work has on the planet. You can even take part in our Carbon Zero* programme, and offset the entire carbon footprint of your laptop. *Carbon Zero available in UK only. -
Services for a flawless performance
The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
- Dynabook Toshiba Satellite Pro A40-D-1KT - 14" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell - up to 8 hours
- Accelerometer
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Cosmo Silver, tile black (keyboard)
- 34.01 cm x 24.41 cm x 2.38 cm
- 1.75 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - pick-up and return - 1 year - carry-in
- Bundled Services
- 1 Year Reliability Guarantee
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 SATA
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Video Resolutions
- 1920 x 1080
- Sound
- Stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, touchpad
- Multi-gesture touch pad, Palm Rejection Technology
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack , USB 3.0 (Sleep & Charge)
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Microsoft 365 (30 days trial), DTS Studio Sound
- Integrated Options
- Accelerometer
- Security
- Administrator password, system password, hard drive password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.75 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
