Dynabook Portege X40-G-10Z Intel Core i5-10210U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: G0CHWS00 Mfr#: A1PMR41E111F
  • Core i5
  • IEEE 802.11n
The Dynabook Portégé X40 puts productivity and privacy first. Combining innovative business features within a sleek, mobile and robust design, it's elegantly engineered to help you power through every working day with the utmost security.
  • Add power to your day
    The Portégé X40 delivers everything you need to meet the demands of modern business. You'll find a powerful Intel Optane SSD – with up to 1 TB of storage – within its thin and light chassis. And with the latest ultra-fast Intel Wi-Fi 6 modules, you can connect with improved security, higher throughput and improved network capacity.
  • Work with confidence
    We've tested the Portégé X40 extensively – so we know it can withstand the bumps and strains of mobile working. And the security is just as robust as the magnesium chassis. Armed with two-factor authentication, including IR-based Windows Hello and a built-in SecurePad with fingerprint reader, you can accelerate your way through your daily tasks with confidence. An optional dynamic privacy filter lets you instantly restrict the viewing angle of your screen so your work is for your eyes only; moreover, a camera shutter slider assures your own privacy.
  • Stay cool
    When the pressure is on, some laptops can start showing the strain – but the Portégé X40 isn't one of them. Our new S-Type cooling system works tirelessly and quietly to protect against overheating. With a reduced fan speed that produces less noise while improving performance, you can stay cool and meet deadlines throughout the working day.
  • Connect and create
    The Portégé X40's optional mobile broadband – including LTE – means you can access and provide information wherever you are. And once you're connected, you can navigate intuitively using your fingers thanks to In-Cell touch technology. Whatever the lighting conditions, you'll be able to review and create with exceptional clarity on the non-glare screen.
  • Fast as lightning
    The Portégé X40 is always ready to work: with modern standby and a wake on fingerprint feature, you can access information in seconds without having to wait for your laptop to reconnect. Twin Thunderbolt 3 ports connect you to your peripherals in record time. So whether you're plugging in a mouse, uploading information, or sharing a presentation at a client's office, nothing can slow you down. It's everything you need to achieve in a professional environment.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Portégé X40-G-10Z - 14" - Intel Core i5 - 10210U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
8 GB DDR4
Storage
256 GB SSD
Display
14" touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Input Device
AccuPoint, SecurePad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1
3-cell - up to 11.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Onyx blue with hairline
33.2 cm x 22.89 cm x 1.69 cm
1.25 kg
Region: Ireland
Environmental Standards
ENERGY STAR Qualified
0.37 W/kg
EMEA warranty - pick-up and return - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 10210U / 1.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
256 GB SSD M.2 PCIe
Display
14"
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-reflective, in-cell touch technology
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Camera Features
IR camera, Windows Hello
Sound
Harman/kardon stereo speakers, two microphones
Input
Keyboard, AccuPoint, SecurePad
Keyboard Backlight
Glass finished Securepad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Wi-Fi CERTIFIED
3-cell Lithium Ion
Run Time
Up to 11.5 hours
AC Adapter
Input
Output
65 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery/data/video) , HDMI , Headphone/microphone combo jack , USB 3.0 (Sleep & Charge)
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft 365 (30 days trial)
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
SAR Value
0.37 W/kg
0.37 W/kg
Localization
Region: Ireland
1.25 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
