End frustration and simplify labeling with the DYMO XTL 500. A life-like on screen print preview shows exactly how labels will look, while a color touch screen and built-in label applications make getting started easy. Prints labels from ΒΌ" up to 2" wide in a full range of UL-rated materials and colors.
 - DYMO XTL 500 - Kit - labelmaker - B/W - thermal transfer
- Printer Type
 - Labelmaker - thermal transfer - B/W
- Form Factor
 - Portable
- Localisation
 - United Kingdom, Ireland
- Max Media Size
 - Roll (5.4 cm)
- Max Media Size (Custom)
 - 54 mm
- Print Speed
 - Up to 28 mm/sec - max speed
- Max Resolution (B&W)
 - 300 dpi
- Cutter
- Interface
 - USB
- Flash Memory Installed (Max)
 - 41 MB
- Barcodes
 - Code 39, QR code, UPC-A, Codabar, Code 128, PDF417, EAN-8, EAN-13
- Media Type
 - Vinyl labels
 - 24 line printing
- Keyboard
 - QWERTY
- Battery
 - Lithium polymer
- System Requirements
 - Microsoft Windows 7 / 8 / 8.1 / 10
 - 3-year warranty
- Printer Type
 - Labelmaker - thermal transfer - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
 - Character keyboard, touch screen
- Connectivity Technology
 - Wired
- Interface
 - USB
 - 300 dpi
 - 24 line printing
- Auto Cutter
- Keyboard
 - QWERTY
- Barcodes
Flash Memory
- Flash Memory
 - 41 MB
Media Handling
- Media Type
 - Vinyl labels
- Max Media Size
 - Roll (5.4 cm)
 - 54 mm
- Media Sizes
 - Roll (5.4 cm)
- Media Feeders
 - 1 x manual - 1 cassette - Roll (5.4 cm)
- Connections
 - 1 x USB
- Included Accessories
 - Carrying case
- Cables Included
 - 1 x USB cable
- Media Included
 - 1 roll of 150 38 x 39 mm black on white laminated labels, 1 54 mm x 7 m black on white vinyl tape cassette
- Power Device
 - Power adapter - external
 - Lithium polymer
- OS Required
 - Limited warranty - 3 years
