Easy to use and super-strong, RHINO labels designed for the long haul. Thanks to industrial strength adhesives, they deliver the lasting durability and legibility you demand - in six materials, for a multitude of applications. To meet your high standards, RHINO labels are designed to work exclusively with printers and perform on any surface you encounter.
 - DYMO RhinoPRO Self Laminating - labels - 1 roll(s) - Roll (2.4 cm x 5.5 m)
- Product Type
 - Labels
- Product Material
 - Vinyl
- Media Size
- Printing Technology
 - Thermal transfer
- Media Colour
 - Black on white
- Included Qty
 - 1 roll(s)
- Compatible with
 - Rhino 6000, 6000 Hard Case Kit; RhinoPRO 6000
Media
- Media Type
 - Labels
- Product Material
 - Vinyl
- Media Sizes
 - Thermal transfer
- Media Colour
 - Black on white
- Included Qty
 - 1 roll(s)
 - Self-laminating
- Colour Category
 - White
- Compatible with
 - DYMO Rhino 6000, 6000 Hard Case Kit , DYMO RhinoPRO 6000
