DYMO Rhino Pro 5200
DYMO Rhino Pro 5200
Quicklinx: CJ3RWS00 Mfr#: S0841460
Advanced Labeling Tool. Go for the portable, affordable label printer that builds your reputation. Show off your work with Rhino 5200 from DYMO Industrial - the label printer for datacomm, electrical, audio/visual, security, MRO, construction and broadcast professional.
DYMO Rhino 5200 - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
Portable
900 g
Max Media Size
Roll (1.9 cm)
Min Media Size (Custom)
6 mm
Max Media Size (Custom)
19 mm
Cutter
Barcodes
Code 39, Code 128
Media Type
Flexible nylon tape, permanent adhesive vinyl tape, polypropylene inserts, permanent adhesive polyester tape
Character Sizes
7 sizes
Styles & Effects
Bold, narrow, italic, underline, boxes around text
Required 6 x AA type
2-year warranty with product registration
Printer Type
Labelmaker - thermal transfer - monochrome
Printer
Built-in Devices
Preview screen, character keyboard
Character Sizes
7 sizes
Styles & Effects
Auto Cutter
Barcodes
Code 39, Code 128
Media Handling
Media Type
Max Media Size
Roll (1.9 cm)
6 mm
19 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
Media Feeders
1 x manual - 1 cassette - Roll (1.9 cm)
Rugged
CISPR 22 Class B, CISPR 24, EN 61000-3-2, IEC950, UL 1950, EN 61000-3-3, EN55024, EN55022 Class B, EN 61000-6-1, FCC Part 15 B, AS/NZS 60950-1, EN 61000-4-4, EN 61000-4-2, EN50204, EN 61000-4-3, EN 61000-4-6, EMC, EN 61000-4-5, EN 55020, CISPR 13, CISPR 20, EN55013, EN 61000-4-11, EN 61000-4-8, UL 60950-1, EN 60950-1, WEEE, EN 61000-6-3, UL 2054
AA type
Required Qty
6
900 g
CJ3R DYMO Black on white 12mm col vinyl In Stock £14.53
CJ3R DYMO ID1 19mm - 1300mm Flexible Nylon - White In Stock £18.21
