The Rhino 6000 is an ideal label printer for high-end, demanding datacom, electrical, pro audio/video systems and MRO applications, loaded with revolutionary, time-saving features. With exclusive "hot keys", you'll eliminate guesswork and enjoy fast and easy formatting of commonly used label types for marking wire and cable, terminal blocks, patch panels and much more. Rhino 6000's intuitive graphical interface lets you easily create, edit and preview multiple labels on the large backlit LCD. A library of over 250 easy-to-find industry terms and symbols helps you save typing time - plus save over 1,000 of your own custom labels and recall them instantly.
- DYMO Rhino 6000 Hard Case Kit - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 2.4 kg
- Max Media Size
- Roll (2.4 cm)
- Min Media Size (Custom)
- 6 mm
- Max Media Size (Custom)
- 24 mm
- Cutter
- Interface
- USB
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128
- Media Type
- Flexible nylon tape, self-laminating vinyl labels, permanent adhesive vinyl tape, polypropylene inserts, permanent adhesive polyester tape, non-adhesive polypropylene tag
- Fonts
- BIG
- Character Sizes
- 8 sizes
- Styles & Effects
- Bold, normal, narrow, vertical, italic, underline, boxes around text
- Keyboard
- ABCD
- Battery
- Lithium Ion
- 45.7 cm x 10.2 cm x 35.6 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Built-in Devices
- Preview screen, character keyboard, cutter
- Connectivity Technology
- Wired
- Interface
- USB
- Fonts
- BIG
- Character Sizes
- 8 sizes
- Styles & Effects
- Auto Cutter
- Keyboard
- ABCD
- Repeating Printing
- 99 copies
- Barcodes
Media Handling
- Media Type
- Max Media Size
- Roll (2.4 cm)
- 6 mm
- 24 mm
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
- Media Feeders
- 1 x manual - 1 cassette - Roll (2.4 cm)
- Connections
- 1 x USB - 4 pin USB Type B
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable
- Media Included
- 1 24mm black on white flexible nylon label cassette, 1 9mm black on white vinyl label cassette
- Hot keys, rugged
- FCC Class B certified, EN 60950, EN 61000-3-2, IEC950, UL 1950, EN 61000-3-3, EN55024, EN 61000-4-4, EN 61000-4-2, EN50204, EN 61000-4-3, EN 61000-4-6, EMC, EN 61000-4-5, EN 61000-4-11, RoHS, EN 61000-4-8, EN 61000-6-3
- Power Device
- Power adapter - external
- Lithium Ion
- Software Included
- RHINO CONNECT Software
- 45.7 cm
- 10.2 cm
- 35.6 cm
- 2.4 kg
