DYMO Rhino 5200 Mono Labelmaker
Quicklinx: 6N6GWS00 Mfr#: S0841460
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: [N/A]
Technology: Direct thermal
£93.24 ex VAT
£111.88 inc VAT
RHINO 5200 from DYMO industrial - the portable, affordable label printer is for datacomm, electrical, audio/visual, security, MRO, construction and broadcast professionals. It's easier than ever to give your installations a neat, professional look that builds your reputation! Fast, rugged and packed with time-saving features, RHINO 5200 meets all ANSI, TIA/EIA-606-A labeling standards, and is designed for professional installers in real-world jobsite conditions. Hot-keys - a RHINO exclusive - make it easy to print pre-formatted labels for wire and cable, terminal blocks, 110 blocks, electrical and patch panels, vertical and fixed lengths. An extensive pre-programmed symbol library puts industry symbols, basic punctuation, currency and fractions at your fingertips. Separate "save" and "recall" buttons prevent repeated work, and smart onscreen alerts help prevent mistakes and wasted labels. Built to perform wherever you work, RHINO 5200 includes an integrated, slip-resistant rubber grip/bumper that protects against damage from accidental bumps and falls, and an integrated lanyard loop for option of hands-free portability.
DYMO Rhino 5200 - labelmaker - B/W
Printer Type
Labelmaker - B/W
Portable
0.9 kg
Max Media Size
Roll (1.9 cm)
Max Media Size (Custom)
19 mm
Barcodes
Code 39, Code 128
Media Type
Sleeves, flexible nylon tape, permanent adhesive vinyl tape, permanent adhesive polyester tape, non-adhesive tag
Character Sizes
7 sizes
Styles & Effects
6 styles
Required 6 x AA type
Printer Type
Labelmaker - monochrome
Printer
Built-in Devices
Preview screen, character keyboard, cutter
Character Sizes
7 sizes
Styles & Effects
6 styles
Barcodes
Code 39, Code 128
Media Handling
Media Type
Max Media Size
Roll (1.9 cm)
19 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
Media Feeders
1 x manual - 1 cassette - Roll (1.9 cm)
Media Included
1 19mm white flexible nylon tape
AA type
Required Qty
6
0.9 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (1.9 cm)
Brand: DYMO
Price Range Ex VAT: 50 - 100
