LabelWriter Print Server allows you to share your LabelWriter printers with your co-workers, connect any LabelWriter 400 or 450 series printer to your network and maximize your LabelWriter label printer usage. Easy set up - just plug in the power supply, connect to a network jack and your LabelWriter printer, and install the software on a single workstation. No extra cables required.
- DYMO - print server - USB
- Print server
- Form Factor
- External
- Interface (Bus) Type
- USB
- Localisation
- United Kingdom
- Data Link Protocol
- 10Mb LAN
- System Requirements
- Microsoft Windows XP, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista (32/64 bits)
- Designed For
- DYMO LabelWriter 400, 400 Duo, 400 Turbo, 400 Twin Turbo, 450, 450 Duo, 450 Turbo, 450 Twin Turbo, 4XL
- Print server
- Form Factor
- External
- USB
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Ethernet
- 1 x Ethernet - RJ-45
- Connections
- 1 x USB
- Power Device
- Power adapter - external
- OS Required
- Designed For
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
