DYMO LabelWriter 4XL Mono Direct Thermal Label Printer
Quicklinx: 7D0RWS00 Mfr#: S0904960
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£240.98 ex VAT
£289.17 inc VAT
Tackle high-volume dispatch, mailing and business labeling jobs. Install a DYMO LabelWriter 4XL printer in your office or workplace and you're ready for any mailing or labeling job that comes your way. Print extra large dispatch warehouse labels, plus over 100 label styles such as file folders, name badges and more. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 4XL - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
0.78 kg
Max Media Size
Roll (11.5 cm)
Print Speed
Up to 53 labels/min
Max Resolution (B&W)
300 dpi
USB
Media Type
Thermal labels
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
17.9 cm x 18.7 cm x 13.5 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 53 labels/min
Wired
USB
300 dpi
Media Handling
Media Type
Thermal labels
Max Media Size
Roll (11.5 cm)
Media Sizes
Roll (11.5 cm)
Max Printing Width
105.7 mm
Media Feeders
1 x manual - 1 roll - Roll (11.5 cm)
1 x USB - 4 pin USB Type B
1 x USB cable
C-Tick, GS, CB, FCC, cTUVus
Software Included
Drivers & Utilities
17.9 cm
18.7 cm
13.5 cm
0.78 kg
Ink (5)
7D0R DYMO 11353 Multi-use Labels In Stock £18.03
7D0R DYMO LabelWriter MultiPurpose - multi-purpose labels - 500 label(s) - 19 x 51 mm In Stock £8.86
7D0R DYMO Multi-Purpose White labels In Stock £18.21
7D0R DYMO Shipping/Name Badges - White - 54x101 mm - 220 Labels In Stock £14.71
7D0R DYMO LabelWriter Standard Address Labels - White In Stock £9.02
Other bundles (2)
7D0R DYMO Return Address Labels In Stock £11.98
7D0R DYMO Suspension file labels - white - 50 x 12 mm - 220 label(s) In Stock £8.80
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (11.5 cm)
Brand: DYMO
