Tackle high-volume dispatch, mailing and business labeling jobs. Install a DYMO LabelWriter 4XL printer in your office or workplace and you're ready for any mailing or labeling job that comes your way. Print extra large dispatch warehouse labels, plus over 100 label styles such as file folders, name badges and more. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
- DYMO LabelWriter 4XL - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 0.78 kg
- Max Media Size
- Roll (11.5 cm)
- Print Speed
- Up to 53 labels/min
- Max Resolution (B&W)
- 300 dpi
- Interface
- USB
- Media Type
- Thermal labels
- System Requirements
- Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
- 2-year warranty
- 17.9 cm x 18.7 cm x 13.5 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 300 dpi
Media Handling
- Media Type
- Thermal labels
- Max Media Size
- Roll (11.5 cm)
- Media Sizes
- Roll (11.5 cm)
- Max Printing Width
- 105.7 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.5 cm)
- Connections
- 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- C-Tick, GS, CB, FCC, cTUVus
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 17.9 cm
- 18.7 cm
- 13.5 cm
- 0.78 kg
Ink (5)
DYMO 11353 Multi-use Labels | In Stock | £13.93 |
DYMO LabelWriter MultiPurpose - multi-purpose labels - 500 label(s) - 19 x 51 mm | In Stock | £8.94 |
DYMO Multi-Purpose White labels | In Stock | £18.30 |
DYMO Shipping/Name Badges - White - 54x101 mm - 220 Labels | In Stock | £14.44 |
DYMO LabelWriter Standard Address Labels - White | In Stock | £8.56 |
Other bundles (2)
DYMO Return Address Labels | In Stock | £11.62 |
DYMO Suspension file labels - white - 50 x 12 mm - 220 label(s) | In Stock | £8.88 |
