The LabelWriter 450 Turbo prints impressive labels at very high speeds, taking office labeling to another level. Professional labeling and mailing solution for your busy office. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
- DYMO LabelWriter 450 Turbo - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 0.68 kg
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 71 labels/min - B/W - Roll (6.2 cm)
- Max Resolution (B&W)
- 600 x 300 dpi
- Interface
- USB
- Media Type
- Labels, thermal paper
- System Requirements
- Microsoft Windows XP, Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits)
- 2-year warranty
- 12.4 cm x 18.4 cm x 14.6 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 600 x 300 dpi
Media Handling
- Media Type
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 56 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6.2 cm)
- Connections
- 1 x USB 2.0
- FCC Class B certified, TUV, TUV GS, C-Tick, IEC 60950, CB, FCC Part 15, FCC, cTUVus
- Power Device
- Power adapter - external
- Software Included
- DYMO Label Software 8
- OS Required
- Limited warranty - 2 years
- 12.4 cm
- 18.4 cm
- 14.6 cm
- 0.68 kg
Ink (4)
DYMO LabelWriter MultiPurpose - multi-purpose labels - 500 label(s) - 19 x 51 mm | In Stock | £9.12 |
DYMO Multi-Purpose White labels | In Stock | £18.19 |
DYMO Shipping/Name Badges - White - 54x101 mm - 220 Labels | In Stock | £15.12 |
DYMO LabelWriter Standard Address Labels - White | In Stock | £9.04 |
Other bundles (3)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.02 |
DYMO Return Address Labels | In Stock | £11.98 |
DYMO Suspension file labels - white - 50 x 12 mm - 220 label(s) | In Stock | £9.04 |
