DYMO LabelWriter 450 Duo Mono Direct Thermal Label Printer
Quicklinx: 869QWS00 Mfr#: S0838960
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£196.13 ex VAT
£235.35 inc VAT
Print the widest variety of DYMO labels with one versatile printer. With the ability to print paper and permanent D1 plastic labels, you're ready to tackle virtually any labeling job. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 450 Duo - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 71 labels/min - B/W
Max Resolution (B&W)
600 x 300 dpi
USB
Media Type
Labels, thermal paper, plastic tape
Compatible Tapes
D1 tape
Microsoft Windows XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits)
12.7 cm x 19.7 cm x 18.4 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Wired
USB
600 x 300 dpi
Media Handling
Media Type
Compatible Tapes
D1 tape
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (5.4 cm), Roll (2.4 cm), Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm), Roll (3.8 cm), Roll (3.6cm), Roll (5.1cm), Roll (3.2 cm), Roll (2.5 cm), Roll (6.2 cm), Roll (2.8 cm), Roll (5.9 cm)
Max Printing Width
56 mm
1 x USB
Cleaning kit
1 x USB cable
Power adapter - external
Software Included
DYMO Label Software 8
12.7 cm
19.7 cm
18.4 cm
Ink (11)
869Q DYMO D1 12mm Tape - Black on Yellow In Stock £14.36
869Q DYMO Black on White 12mm tape In Stock £14.44
869Q DYMO Black on white 12mm col vinyl In Stock £14.54
869Q DYMO LabelWriter MultiPurpose - multi-purpose labels - 500 label(s) - 19 x 51 mm In Stock £8.93
869Q DYMO D1 - Glossy tape - black on white - Roll (2.4 cm x 7 m) - 1 roll(s) In Stock £24.56
869Q DYMO D1 - Tape 6MMX7M In Stock £12.21
869Q DYMO ID1 19mm - 1300mm Flexible Nylon - White In Stock £18.22
869Q DYMO Multi-Purpose White labels In Stock £18.17
869Q DYMO Shipping/Name Badges - White - 54x101 mm - 220 Labels In Stock £15.04
869Q DYMO LabelWriter Standard Address Labels - White In Stock £9.03
869Q DYMO Flexible Nylon Tape - Black on White - 1.2cm x 3.5m 1 roll In Stock £16.06
Other bundles (3)
869Q DYMO D1 12mm Tape Black/White In Stock £14.44
869Q DYMO Return Address Labels In Stock £11.96
869Q DYMO Suspension file labels - white - 50 x 12 mm - 220 label(s) In Stock £9.03
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (6.2 cm)
Brand: DYMO
