Print the widest variety of DYMO labels with one versatile printer. With the ability to print paper and permanent D1 plastic labels, you're ready to tackle virtually any labeling job. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
- DYMO LabelWriter 450 Duo - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 71 labels/min - B/W
- Max Resolution (B&W)
- 600 x 300 dpi
- Interface
- USB
- Media Type
- Labels, thermal paper, plastic tape
- Compatible Tapes
- D1 tape
- System Requirements
- Microsoft Windows XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits)
- 12.7 cm x 19.7 cm x 18.4 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 600 x 300 dpi
Media Handling
- Media Type
- Compatible Tapes
- D1 tape
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (5.4 cm), Roll (2.4 cm), Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm), Roll (3.8 cm), Roll (3.6cm), Roll (5.1cm), Roll (3.2 cm), Roll (2.5 cm), Roll (6.2 cm), Roll (2.8 cm), Roll (5.9 cm)
- Max Printing Width
- 56 mm
- Connections
- 1 x USB
- Included Accessories
- Cleaning kit
- Cables Included
- 1 x USB cable
- Power Device
- Power adapter - external
- Software Included
- DYMO Label Software 8
- OS Required
- 12.7 cm
- 19.7 cm
- 18.4 cm
Ink (14)
DYMO D1 12mm Tape - Black on Yellow | In Stock | £12.03 |
DYMO Black on White 12mm tape | In Stock | £12.03 |
DYMO Black on white 12mm col vinyl | In Stock | £14.40 |
DYMO 11353 Multi-use Labels | In Stock | £13.93 |
DYMO LabelWriter MultiPurpose - multi-purpose labels - 500 label(s) - 19 x 51 mm | In Stock | £9.01 |
DYMO D1 - Glossy tape - black on white - Roll (2.4 cm x 7 m) - 1 roll(s) | In Stock | £23.27 |
DYMO D1 - Tape 6MMX7M | In Stock | £12.70 |
DYMO ID1 19mm - 1300mm Flexible Nylon - White | In Stock | £18.03 |
DYMO Multi-Purpose White labels | In Stock | £18.30 |
DYMO Shipping/Name Badges - White - 54x101 mm - 220 Labels | In Stock | £14.44 |
DYMO D1 Tape 9mm Black on Transparent | In Stock | £13.74 |
DYMO LabelWriter Standard Address Labels - White | In Stock | £8.56 |
DYMO Flexible Nylon Tape - Black on White - 1.2cm x 3.5m 1 roll | In Stock | £16.12 |
DYMO D1 Self-Adhesive Label Tape 1 Roll - Black on Green | In Stock | £14.70 |
Other bundles (3)
DYMO D1 12mm Tape Black/White | In Stock | £12.03 |
DYMO Return Address Labels | In Stock | £11.62 |
DYMO Suspension file labels - white - 50 x 12 mm - 220 label(s) | In Stock | £8.93 |
