Finally, printing a label is fast and easy! With the DYMO LabelManager PnP Label Maker there's no software to install - just plug in to your PC or MAC and create great-looking labels as fast as you can type.
- DYMO LabelMANAGER PnP - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- 329 g
- Max Media Size
- Roll (1.2 cm)
- Max Media Size (Custom)
- 12 mm
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Interface
- USB
- Media Type
- Self-adhesive label tape
- Compatible Tapes
- D1 tape
- Battery
- Lithium Ion
- System Requirements
- Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
- 13.6 cm x 14.2 cm x 5.3 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Connectivity Technology
- Wired
- Interface
- USB
- 180 dpi
- Cutter
Media Handling
- Media Type
- Compatible Tapes
- D1 tape
- Max Media Size
- Roll (1.2 cm)
- 12 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm)
- Media Feeders
- 1 x manual - 1 roll - Roll (1.2 cm)
- Connections
- 1 x USB
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x tape cassette
- Lithium Ion
- Software Included
- DYMO Label Software 8
- OS Required
- 13.6 cm
- 14.2 cm
- 5.3 cm
- 329 g
Ink (10)
DYMO D1 12mm Tape - Black on Yellow | In Stock | £12.03 |
DYMO Black on White 12mm tape | In Stock | £12.04 |
DYMO Black on white 12mm col vinyl | In Stock | £14.60 |
DYMO D1 9mm Tape - Black on Yellow | In Stock | £12.48 |
DYMO D1 - Tape 6MMX7M | In Stock | £11.74 |
DYMO D1 Tape 12mm White on Transparent | In Stock | £14.50 |
DYMO D1 Tape Permanent 12mm x 5.5m Black on White | In Stock | £14.50 |
DYMO D1 Tape Black on Yellow | In Stock | £18.32 |
DYMO Tape 24mm Black on Yellow | In Stock | £19.17 |
DYMO D1 Self-Adhesive Label Tape 1 Roll - Black on Green | In Stock | £14.50 |
Other bundles (1)
DYMO D1 12mm Tape Black/White | In Stock | £12.04 |
