DYMO LabelMANAGER PnP Mono Thermal Transfer Labelmaker
Quicklinx: 7CM2WS00 Mfr#: S0915390
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
£43.61 ex VAT
£52.33 inc VAT
Finally, printing a label is fast and easy! With the DYMO LabelManager PnP Label Maker there's no software to install - just plug in to your PC or MAC and create great-looking labels as fast as you can type.
DYMO LabelMANAGER PnP - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
329 g
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
12 mm
Max Resolution (B&W)
180 dpi
Cutter
USB
Media Type
Self-adhesive label tape
Compatible Tapes
D1 tape
Lithium Ion
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
13.6 cm x 14.2 cm x 5.3 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Printer
Wired
USB
180 dpi
Cutter
Media Handling
Media Type
Compatible Tapes
D1 tape
Max Media Size
Roll (1.2 cm)
12 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm)
Media Feeders
1 x manual - 1 roll - Roll (1.2 cm)
1 x USB
1 x USB cable
Consumables Included
1 x tape cassette
Lithium Ion
Software Included
DYMO Label Software 8
13.6 cm
14.2 cm
5.3 cm
329 g
Ink (7)
7CM2 DYMO D1 12mm Tape - Black on Yellow In Stock £14.26
7CM2 DYMO Black on White 12mm tape In Stock £14.57
7CM2 DYMO Black on white 12mm col vinyl In Stock £14.67
7CM2 DYMO D1 9mm Tape - Black on Yellow In Stock £13.41
7CM2 DYMO D1 - Tape 6MMX7M In Stock £12.31
7CM2 DYMO D1 Tape Permanent 12mm x 5.5m Black on White In Stock £14.14
7CM2 DYMO Tape 24mm Black on Yellow In Stock £18.69
Other bundles (1)
7CM2 DYMO D1 12mm Tape Black/White In Stock £14.57
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (1.2 cm)
Brand: DYMO
