DYMO LabelManager 500TS Label Maker
Quicklinx: BDD4WS00 Mfr#: S0946420
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
£190.26 ex VAT
£228.31 inc VAT
Touch Screen Label maker with PC or MAC connection. The first standalone office touch screen label maker from DYMO.
DYMO LabelMANAGER 500TS - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
0.8 kg
Hong Kong, United Kingdom
Max Media Size
Roll (2.4 cm)
Max Resolution (B&W)
300 dpi
Cutter
USB
Media Type
Labels
Compatible Tapes
D1 tape
Fonts
10 fonts
Character Sizes
25 sizes
Styles & Effects
Bold, normal, vertical, outline, italic, Mirror, strikethrough
Keyboard
QWERTY
Required 1 Included Qty 1
Enclosure Colour
Black, silver
3-year warranty with product registration
16.5 cm x 19 cm x 9.5 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Enclosure Colour
Black, silver
Printer
Built-in Devices
Character keyboard, touch screen
Wired
USB
300 dpi
Fonts
10 fonts
Character Sizes
25 sizes
Styles & Effects
Auto Cutter
Keyboard
QWERTY
Media Handling
Media Type
Labels
Compatible Tapes
D1 tape
Max Media Size
Roll (2.4 cm)
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
Media Feeders
1 x manual - 1 roll - Roll (2.4 cm)
1 x USB
1 x USB cable
Power adapter - external
Required Qty
1
Included
1
Limited warranty - 3 years
16.5 cm
19 cm
9.5 cm
0.8 kg
BDD4 DYMO D1 12mm Tape - Black on Yellow In Stock £12.39
BDD4 DYMO Black on White 12mm tape In Stock £14.19
BDD4 DYMO D1 9mm Tape - Black on Yellow In Stock £14.17
BDD4 DYMO D1 - Glossy tape - black on white - Roll (2.4 cm x 7 m) - 1 roll(s) In Stock £24.13
BDD4 DYMO D1 - Tape 6MMX7M In Stock £12.70
BDD4 DYMO D1 Tape 12mm White on Transparent In Stock £14.20
BDD4 DYMO D1 Tape Permanent 12mm x 5.5m Black on White In Stock £14.20
BDD4 DYMO D1 Tape 9mm Black on Transparent In Stock £13.74
BDD4 DYMO Tape 24mm Black on Yellow In Stock £18.77
BDD4 DYMO D1 Self-Adhesive Label Tape 1 Roll - Black on Green In Stock £14.70
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (2.4 cm)
Brand: DYMO
