Long lasting power you can trust. That's a Duracell battery. Depend on it. Duracell provides you with a wide range of powerful batteries to run most devices technology can put in your hand.
Duracell is the world's leading manufacturer and marketer of high-performance alkaline batteries and other consumer batteries. Whether you're finding your way at night with a flashlight, making a call on your cellular phone, or showing your child how to use a toy - you can trust Duracell. Why? Because Duracell batteries give you the high level of quality and long-lasting performance you demand at a good value.
- Duracell battery - 12 x AA type - Alkaline
- Product Type
- Battery
- 1.4 cm x 1.4 cm x 5 cm
- Localisation
- English
- Battery
- AA type - Alkaline - 2850 mAh
- Batteries Included
- 12 pcs.
- Product Type
- Battery
- 1.4 cm
- 1.4 cm
- 5 cm
- Localisation
- English
- AA type
- Technology
- Alkaline
- Included Qty
- 12
- Voltage Provided
- 1.5 V
- Capacity
- 2850 mAh
