Mains Charger for Micro USB Devices
The Duracell range of Mobile Phone Power accessories provide superior quality performance in a superbly designed charger. As you would expect from such a trusted name as Duracell.
For all Smartphone and Tablet PCs with a Micro USB socket.
The Home Charger is finished in Black and supplied with a 3 pin plug.
- Duracell power adapter - Micro-USB Type B
- Product Type
- Power adapter
- 5.5 cm x 4.9 cm x 4.8 cm
- 80 g
- Black
- Localisation
- United Kingdom
- Output Connector Type
- Micro-USB Type B
- Voltage Required
- AC 230 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2.4 A
- 3-year warranty
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- 5.5 cm
- 4.9 cm
- 4.8 cm
- 80 g
- Enclosure Colour
- Black
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- Input Connectors
- Power 3-pole
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 5 pin Micro-USB Type B
- 2.4 A
- Limited warranty - 3 years
