The Duracell compact battery charger is a fantastic product that can fully charge your camera and camcorder battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home.
This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery.
- Duracell DR5700I-UK battery charger
- Product Type
- Battery charger
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- 3-year warranty
- Designed For
- Casio NP-100, 20, 40, 40DBA, 50, 60, 70, 80, 80DBA, 90
- Product Type
- Battery charger
- Designed For
- Camcorder, camera
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- LED indicator
- Limited warranty - 3 years
- Designed For
