High quality lithium -ion rechargeable battery. Each battery is guaranteed 'no memory effect'. Duracell's products are designed to give you maximum power. Whatever your power needs, you can take more photos with Duracell.
- Duracell camera battery - Li-Ion
- Product Type
- Camera battery
- 4.1 cm x 3.4 cm x 0.7 cm
- 17 g
- Battery
- Lithium Ion - 770 mAh
- Manufacturer Battery Name
- Olympus Li-50B
- 3-year warranty
- Designed For
- Olympus µ[MJU:] 1010, 1020, 1030 SW, 9000, TOUGH-6000, TOUGH-8000
- Product Type
- Camera battery
- Designed For
- Camera
- 4.1 cm
- 3.4 cm
- 0.7 cm
- 17 g
- Olympus Li-50B
- Technology
- Lithium Ion
- Voltage Provided
- 3.7 V
- Capacity
- 770 mAh
- Limited warranty - 3 years
- Designed For
